| Off-Topic Talk about anything other than cars. |
I just measured my crank out of my 4G63 for bend. It is bent .008 in and the rod journal where it spun a bearing is worn to far to be machined. Now I either need a new crank or a remanufactured one.
Does anyone know where I can get one? The only one I can find is $425 and I was told someplace has them for $250. Can anybody help?
Tim's 95 Eagle Talon TSI 4G63T |
Re: Crankshaft Problem?
It sounds like your car may have crankwalked...I find it hard to believe that the crank itself bent.
If I were you I would be looking for a 6bolt 1g motor to swap in. EDIT>> I thought you were explaining that your bearing failed...are you positive the problem is with the crank itself and not the thrust bearings? How did you measure this distance...is it endplay or what?
1996 Eagle Talon Last edited by joemathews; 12-06-2004 at 09:35 PM. |
Re: Re: Crankshaft Problem?
Re: Re: Re: Crankshaft Problem?
Tim's 95 Eagle Talon TSI 4G63T Last edited by timmaytalon; 12-06-2004 at 10:21 PM. |
sorry to semi-jack this thread, but i've heard the term crankwalk used a bit around here, but i never knew what it is. explanation anyone?
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv ![]() ![]() Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM |
Please don't hijack the thread, crankwalk is explained in detail in the FAQ.
Timmay, I don't know where to find them taht cheap, but I'll keep my eyes open.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
http://www.slowboyracing.com has a remanufactured one for $350.
to answer your question to gen2gst95's post is because crankwalk in the 6 bolt motor is pretty rare. there aren't many occasions of it happening like in the 2g turbos. plus the 6 bolt motor is quite a bit stronger anyways. always a good choice to do the swap if you plan on modding your car in the future. just fyi |
No, you need a 6-bolt block.
![]() 95 GSX DSMlink, "50 Trim", and track times coming VERY SOON!
Re: Re: Re: Re: Crankshaft Problem?
delete your other thread and keep all your questions about the same problem in one thread
as far as i know you need a 6 bolt block to use a 6 bolt crank.
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
