Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-01-2002, 05:05 PM
vidaloca vidaloca is offline
Send a message via AIM to vidaloca
Question SUSPENION help
Ok my question is this....I have a 91 Honda Accord and I know they are notorious for having bad camber when lowered......I am planning to lower the car no more than 1.2 inches all the way around......I have 17x7 rims does anyone know if I will have a camber problem or even need a camber kit w. this mild drop?....anyone running a similar setup?
Race till tha head blows.......buy a new car and then do it again.
¿dónde está las chicas?
Old 03-01-2002, 07:18 PM
HONDA_99 HONDA_99 is offline
rule of thumb; lowering for more then 1.5" requires camber kit to fix alignment.
if you not going to exeed 1.5" you won't need camber kit, but you need go to alignment (tire) shop to get your suspension realign to factory spec.
Old 03-01-2002, 09:53 PM
changedagame108 changedagame108 is offline
With a 1.2'' drop, you should be fine. But get the alignment and make sure everything's ok. Good luck.
Old 03-01-2002, 11:23 PM
another question
I am riding on my factory shocks will this slight drop blow them?.....i plan on gettin aftermarket shocks but this is small drop is until i get the money for a camber kit and shocks.
Old 03-02-2002, 12:57 PM
99% chance you won't need camber kit with 1.2" drop.
1.2" drop will shorten life of your struts, but expect 1.5-2 years before struts gonna go with 1.2" drop.
