Old 12-06-2004, 04:26 PM
drumcat's Avatar
drumcat drumcat is offline
Fuel Injection
I have three choices, MPI EFI or updgrade my TBI. I would like to get some opinions from you guys on which you would suggest for my setup.
I have a 350ci 330hp crate. (Links below pictures)
Option #1
MPI
Option #2
TBI
Option #3
EFI
Option #4
TBI #2
Old 12-07-2004, 05:44 AM
drumcat's Avatar
Re: Fuel Injection
16 views and no one has any comments?
Old 12-07-2004, 09:05 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Fuel Injection
option 1
Old 12-07-2004, 12:08 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
ditto
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 12-10-2004, 10:42 AM
hellraiser319's Avatar
hellraiser319 hellraiser319 is offline
Registered User
Re: Fuel Injection
tbi definately you already have the bulk of it just upgrade it and itll be cheaper. hell if you havethe stock unit, take a dremel to it a bit, make sure theres 350 injectors in it and that should be good but anyway both of those look like the holleys, didnt click links cuz lazy, but id go with the 4bbl if ur headin more towards performance but id go with the 2bbl if ur drivin it every day. just make sure you update the chip if ur still usin stock computer
Old 12-10-2004, 10:45 AM
Registered User
Re: Fuel Injection
also i forgot to mention, mfi is usually only good for low end torque. tbi is like a carb and you get more high end torque with more efficiency. another thing to keep in mind
Old 12-10-2004, 12:58 PM
SHannonh SHannonh is offline
Re: Fuel Injection
Go with www.lt1intake.com
You will find much better gains and you will not have to modify much
-Shannon
Old 12-10-2004, 01:26 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Fuel Injection
well if its your daily driver, then i say go with option 2 or 3. but if you go 2, then just hit up the junkyard and get the throttle body off of a 350 TBI GM truck. bolts right on, all the connectors are direct connect, and increases flow by something like 50%. If you are going to bother doing substancial work, then i say install the EFI kit. the MPI kit is going to require the most work, the EFI kit at least allows you to reuse some stuff from the original setup.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 12-20-2004, 04:24 PM
drumcat's Avatar
Re: Fuel Injection
Ok so the TBI upgrade will definately give me better performance (torque & hp) The MPI is going to give me more low end torgue, but is it going to increase horsepower substantialy? or just improve effeciency
Old 12-23-2004, 12:49 PM
Morley Morley is offline
Re: Re: Fuel Injection
No. TBI can't perform like MPFI. As mentioned above go for the LT1 conversion. I work with the guy that does those and have seen his car, they are a real performer and will make more HP than TBI can ever hope to.
Not to mention that is probably the cheapest MPFI conversion going.
