Alternator upgrade?
Ok, so here's the dilemma:
I have and '03 5.3L and I have upgraded my stereo system. I added a 500 watt amplifier (2 ohms total), and a 1 farad capacitor. When I turn it up my headlights and dashlights dim with bass hits, even with the help of the cap. I thought I hosed something up at first so I asked around and a friend of mine said his 4.8L does the same thing. I asked a reputable stereo installation shop and they said the only fix would be to drop in a 6.0L, because they have a better alternator. I looked on Autozone's website and their replacement alternator for a 5.3L is 105 amps, and for a 6.0L is 145 amps. Also 145 for the 5.3L Tahoe, that is kind of a surprise to me, I thought it would be the same as the same size truck. Anyway, I guess my question is, can I just drop in a 145 amp alternator and not fry anything? Does anybody have experience doing anything like this? Any other suggestions? |
Re: Alternator upgrade?
![]() Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft |
Take out the big stereo
do some online hunting, a lot of places sell high output altenators, i had to find one for my 2000 5.3 silverado after i did stereo, found a 200amp that bolted right up and used an adapter plug for wires, u will also have to run a larger wire for alt output to battery
try here http://www.4alterstart.com/pages/sto...om/alternators cut and paste http://www.4alterstart.com/pages/store/skudetail.nhtml?profile=alternators&uid=15654&retu rnURL=http%3A//www.4alterstart.com/alternators
Click To See My Ride 2000 Chevy Silverado LT Z71 K1500 ecsb, 6" suspention lift, 4.56 gaers, 315/75r16 bfg mt, radix supercharger, gibson headers and cat back, trasgo shift kit, aluminum servos, nelson tune |
Or you can.
Get a powermaster alt 200 amps or more for about $400.00.
Look on ebay. Tell the retard who told you to put in a 6.0l that I power two winches and over 12 off road lights with my alt on my jeep and I only have one battery and a 140 amp alt from powermaster. If this guy is into steros and he told you this I hate to see his installs. Please give him on bitch slap from me. |
I'm running two big amps, my digital gauges, my electric fans, and my electric cutouts off of my stock alt. and dry cell battery and I only have headlight dim when my compressor comes on. I'm about to install my three other digital gauges and will be running a nitrous system off of it, when I get to where the truck won't go any faster on motor. I'm going to see what it will take.
Re: Re: Alternator upgrade?
Re: Re: Re: Alternator upgrade?
since this came up; had to buy an alternator LAST NIGHT. stock is 105 with 5 and 3/8 pulley option was 130 with 5 and 3/4 pulley. These were listed at the local advance store. Now If you have a 105 and want to use a 130 you can either go with the longer belt which they list as well or just use the pulley from your 105. Pulley is easily changed with impact. Also since it's only at bass hits have you considered multiple capacitors? Been along time since I installed any big systems but I think (???) it will work.
Also, one more thing that popped into my head. How big of gauge wire are you using to wire the amp/cap?? That makes a HUGE difference. I'd suggest at the least, 4 gauge, if not 2.
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
buttnekked, by chance do you have the part number of the alternator you just bought?
Thanks guys, as always you are very helpful.
I used 4 gauge wire from the battery to the amp, and I am pretty sure that I have more than enough capacitance (I think rule of thumb is 1 farad per 1000 watts, so I have more than enough). I am going to look into getting the delco 150 amp alternator if it is a bolt-in, because I would like to keep everything at least looking stock. If that is not an option I guess I will try out changing the pulleys. |
here ya go nugget: the alternator is P8238 and the shorter belt was 923k6. Just as a side note when reinstalling the belt work from the bottom up and leave the alternator for the last point when you pull the tensioner forward.
I am going through the same problem right now I run a 1500whatt RMS amp to two subs and another 1000whatt RMS amp fo the doors and just before my ears really start to hurt the lights olmost turn off.
I found a local auto parts place that will take my alternator and redo the windings to bring it up to 165amp for around $100 sounds like a good deal and i know it can be done because I have rebuilt starters and alternators before, it's not that hard. Good Luck. |
Has anyone with a 8.1 replaced the AD-230 alternator with a larger bodied/higher amp AD-240 alternator? Does it bolt right in or do you need a new alternator bracket to get the larger alternator to clear the electric throttle module?
![]() 2001 Silverado Crew Cab 2500 HD - 8.1 - Allison 6" RCD Lift with 35" BFG Mud Terrains Airaid Intake - 4" Magnaflow Exhaust - Hypertech Programmer
