Old 12-06-2004, 04:07 PM
Pulowski22_7 Pulowski22_7 is offline
cant get alarm to go off
please help i tried to unlock my car by sticking my hand in the window and unlocking it from the inside now i cant get the damn alarm off. helpppp!!!
Old 12-06-2004, 04:09 PM
aorozco2's Avatar
aorozco2 aorozco2 is offline
Re: cant get alarm to go off
did you get the door to open?
Old 12-06-2004, 04:11 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
close the door, lock it, and then unlock it with your key.
Old 12-06-2004, 06:37 PM
thanks worked perfectly.
later i read my manual and found out. if only i would have read it before. sorry for the trouble
Old 12-06-2004, 07:13 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Lol dosent it turn off after like 5 minutes anyways?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-07-2004, 12:49 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
doesnt turn off after 5 min, you have to disconnet the battery. The first time i set mine off I had no idea how to turn it off. The end result was every girl in the parking lot coming over to help me figure it out.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-07-2004, 01:17 AM
youngvr4's Avatar
STREET RACING GURU
nice
Old 01-15-2005, 02:04 AM
unicyclemidget11 unicyclemidget11 is offline
so if the alarm goes off, close the door, and with your key lock the door and then unlock it?
Old 01-15-2005, 03:04 AM
pr0ject01's Avatar
pr0ject01 pr0ject01 is offline
Send a message via AIM to pr0ject01
yeah make sure the door is closed and turn the key to unlock it. also a problem that i had with my stealth, is when i had it locked with my clicker and then my clicked somehow died or got messed up in the midst of 30 minutes but when i came back out to unlock it the clicker wouldnt work. so i had to unlock it with the key, (there is 2 different alarm systems on the stealth) but yet the alarm would still go off. so then i had to pop the hood and go into the fuse box and unplug the ignition fuse. thus, for unplugging the ingnition fuse is when you try to start the car with the alarm going off it it looses complete battery connection. I was just saying if you guys ever run into this problem. Also.. where can I get a new clicker.. lol?
1991 Dodge Stealth R/t
Old 01-15-2005, 03:51 PM
Igovert500's Avatar
blue + red light magnet
you might just need a new battery...walmart sells 2 for $1.29 or something cheap like that.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-15-2005, 05:18 PM
pr0ject01's Avatar
tried a new battery for the clicker.. but unfortunatly.. still didnt work. and speaking of witch, i was at walmart when it happened..
