Old 12-06-2004, 02:34 PM
m33bp m33bp is offline
96 Z Heat
To all who are out there:
I have a 96 Z28. I have recently replaced the Thermostate, and Radiator Fluid. I am able to get the vehicle up to temp now and it maintains temp, but when I turn the Heater to blow out hot air it doesn't always work. At times it pushes cold air, or luke warm air, rarely it will be hot. What Can I do? Matt
Old 12-06-2004, 11:24 PM
namcoman namcoman is offline
I have the same problem with mine. GM released a technical bulliten a while back about some of the camaro models having a bad seal on the heating unit. This bad seal allows cold air outside to be sucked in with the hot air, thus creating that "lukewarm" feeling. I bet thats your problem but you never know. Good luck.
Old 12-07-2004, 09:02 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 96 Z Heat
and if you put a lower temp stat in, it takes significantly longer to heat up.
Old 12-08-2004, 06:06 PM
poormillionaire2 poormillionaire2 is offline
I just had the exact same problem with mine. I took mine to the shop and had the the radiator properly back-flushed. Apparently, they flushed chunks of crap out, and now its blowing really hot air.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
