Old 12-06-2004, 11:29 AM
Krab Krab is offline
coolant leak...help.
1996 chevy s-10 pickup.
My engine coolant began leaking slightly about three weeks ago. It only leaked after I drove (hot engine). I added coolant directly to the radiator and it kept my truck from overheating but the fluid leak is worsening. Today it overheated to the point where I had to pull over and let it cool down so I could add more coolant. I will be taking it to a shop to have it examined and fixed as I am not very knowledgeable about engines an stuff. But, I am curious as to what exactly is leaking though.
I added more coolant today about two hours after it overheated. Much of it drained back out from somewhere behind and below the flywheels that the belts are on. (the belt assembly located just behind the radiator).
Any ideas on where it is leaking from and why? How much $$ will it take to fix?
Thank you for any help.
Krab
Old 12-06-2004, 12:35 PM
vtmecheng vtmecheng is offline
Re: coolant leak...help.
Sounds like the water pump. I couldn't tell you how much $$ because I replaced my own but can't think it would be too much. Took me like 4-5 hours with a lot of beer breaks.
Old 12-06-2004, 03:27 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
i agree with vt sounds like water pump i cant imagine much more then 300 if that high
Old 12-06-2004, 03:29 PM
it could also be a hose with a small leak and it only is noticeable when on because the system is pressurized forcing fluid out
Old 12-06-2004, 10:36 PM
OverBoardProject OverBoardProject is offline
Banned
vtmecheng don't you mean a lot of beer with some waterpump breaks?
an hour should be lots of time, if you really try
Old 12-07-2004, 12:37 AM
De_pirate De_pirate is offline
yep waterpump and hoses
Old 12-07-2004, 09:17 AM
Hey, after a few breaks it can be hard to tell which of the two water pumps you see is the real one.
