Old 12-06-2004, 11:26 AM
aaamillertime aaamillertime is offline
Send a message via AIM to aaamillertime
97 silverado
O.k. Fuel pump was running for a couple of seconds When turning the ignition on. No fuel pressure at all. Only had 14 pounds of pressure when cranking motor. Replaced fuel pump and inline filter. Exact same symptoms. No pressure. Checked and had power going to wire harness outside fuel tank. Checked and made sure there was no line obstructions. Could the wire connectors going from outside the fuel tank to the inside to the pump be bad and not giving it enough juice.
Any suggestions would be appreciated.
Thanks
Old 12-06-2004, 11:43 AM
djkost djkost is offline
Re: 97 silverado
It is possible that the new pump is bad.
Old 12-06-2004, 12:16 PM
Fireplug Fireplug is offline
Re: 97 silverado
see if you can pinch closed the fuel return line and check if the pressure changes while doing that
Old 12-06-2004, 12:21 PM
Re: Re: 97 silverado
Tried it. Nothing. I even disconnected the fuel line by the tank, & i'm getting a stream of gas but not alot of pressure. Just like the original pump.
Old 12-06-2004, 03:11 PM
Re: 97 silverado
you pinched the fuel return line and got no change in pressure at all???
Old 12-06-2004, 03:48 PM
Re: 97 silverado
Check to see if the fuel pump is wired right. I know you have to remove it again but it might also be a bad pump.
Old 12-06-2004, 07:35 PM
O.K Finally got it running. The finely trained experts at my local AutoZone sold me the wrong fuel pump. They sold me a pump for a Mexico. Which only puts out 12-16 psi. Really stinks because that was the first thing I replaced, ended up spending alot of time and money looking in other directions.
Thanks AutoZone
Thanks for everyones help.
