Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-06-2004, 10:29 AM
93interceptor 93interceptor is offline
oil leak!!!!!!!!!!!
what to do, or where can i go to find out what needs to be done, to pull engine and replace oil pan on a 93 4.6L p71, only have 1 weekend to do it start to finish, any ideas of what else can be done (cheap and easy parts upgrade) while i have the motor out?
Old 12-06-2004, 12:59 PM
landyacht's Avatar
landyacht landyacht is offline
On that age of Crown Vic any mechanic shop can do the jop for you. If it's just leaking, i'd suggest just tightening the bolts on the pan unless you really want to have it replaced.
Something else that could be causing the leak is the valve cover gaskets may be shot. Look for oil residue on the sides of the engine block to see if this is the problem.
The other problem would be the oil seals are fried in which case u definitely need the engine pulled. This is a tell-tale sign if you find you haveing to add oil to the car. Doesn't mean your car is burning oil, it just means that the sucker is leaking like a siv.
I don't have any thoughts on what to do with the motor out of the car... maybe just have the tech (or yourself, whoever is doing it) have a look and see if there's anything they recommend.
Good luck!
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
