Old 12-06-2004, 09:56 AM
Ariffel Ariffel is offline
Help replacing fuel filter
Anyone out there tell me how to replace a fuel filter on a 02 silverado. I did not want to pay the dealer 80 bucks to do something I could do for the price of the filter if I had a general idea how to do it.. Thanks.
Old 12-06-2004, 12:41 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: Help replacing fuel filter
The fuel filter is located on the inside of the passenger side frame rail under the passenger door. There will be a bracket bolted to the frame holding the filter in place , i found it easier to remove the nuts from this bracket. Then make sure the area around the filter is clean , no loose dirt. Remove the fule lines being careful where you do this because there will be some fuel sipllage caused from drainage out of the lines. Then just reverse the procedure to replace it.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 12-06-2004, 02:43 PM
walbern1 walbern1 is offline
I replaced mine last week on my truck, 2002 Silverado ExCab 4.8l and it was on the driver side.
2007 Murano SL AWD
2003 Grand Caravan Sport
If you're not livin on the edge you're takin up too much space!
Old 12-06-2004, 04:01 PM
So should i worry about de-pressurizing the fuel system?
Thanks..
Old 12-06-2004, 04:36 PM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
I didnt depresurize when I did mine. Just dont be under the filter when you break the lines loose and do it slow. Some fuel will spray/leak out but it will depleat rather quickly. When you start the truck back up again it may stumble a little but it will smooth out and run normal.
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
Old 03-17-2005, 09:44 PM
mohdfxr mohdfxr is offline
How do I replace a fuel filter on my 2003 Silverado? How do I deprisure the fuel line?
Old 03-17-2005, 09:54 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
All you do is find the thing, tin can lookin thing, and just loosen the nuts on both sides. DO NOT depressure the line, i have never even heard of doin such a thing. then just put the new one in place and tighten both the nuts.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 03-17-2005, 10:54 PM
silveradoking silveradoking is offline
Yes, that is true...you do not need to depressurize the duel lines to remove the fuel filter....even the mechanic never do, and neither do the stealerships....on 1999 to 2004 models the fuel filter should be on the passenger side under the door on the frame body....2005 models have the filter inside the tank....so you don't need to change it....(or you can change the tank, ever 10,20,30,000 kilometers and have a new filter that way...hehe...)....good luck.....ps. never heard of the filter on the driver's side....
Old 03-18-2005, 02:26 AM
jethro_3's Avatar
jethro_3 jethro_3 is offline
I guess my truck, walbern1's truck and the Hanes manual are the exception. And I guess all the other Silverado's that have the filler neck and tank on the driver side are an exception. Silveradoking, was your truck made in another country? So point being, if the fuel lines are inside the rail which ever side you want to call it, the small can attached to them is the fuel filter.
Have fun figuring it out...
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 03-18-2005, 07:41 AM
airjam18 airjam18 is offline
Maybe its a difference between canadian and american made silvys....I know for a fact that my fuel filter is on the driver's side.....i have changed it plenty.......i think the most logical way to find it would be to look on the side that you put gas in.......either way, just look for a small metal canister with a line running into and out of it......and keep a towel between the filter and the frame to soak up whatever gas does come out......
Old 03-18-2005, 08:22 AM
bowtieguy bowtieguy is offline
well i bought my 02 in texas and my filter too is on the drivers side....so maybe i have a canadian made truck too.
2002 Z71 ext. cab LT trim
badgeless
Rhino spray in liner
Stock for now, other than free mods
future plans (how far in the future depends on wallet)
Toyo Open Country M/T's
air intake (not sure which yet)
exhaust system (seems that Magna flow is the ticket)
Nelson tune
3 or 4 inch lift
Old 03-18-2005, 08:47 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Mine was made in kentucky...same place as y'alls. i ain't de-pressurized anything, just broke the nuts loose and let it drain. After replacing it turned the key on to the "run" position a few times to let the pump fill the filter and re-pressurize the system. Mine never missed a beat.
FYI: There is a rubber o-ring on the end of either fuel line...be sure they are in place before you put the filter on or you will have a leak and loose power..and fuel of course..
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 03-18-2005, 03:20 PM
That's funny...I don't no where my truck isi made, but my fliter is on the passenger side....and I fill my tank on the driver's side (this would be very stupid if someone had to fill their tank on the passenger side....) Anyone Canadian's have their filter on the passenger side? I don't think they make Silverado's in Canada...I know they make it in America and in Mexico, but not Canada.....I think.....
Old 03-18-2005, 05:21 PM
jethro_3's Avatar
So where do the fuel lines cross from the driver side to the passenger side? My filler is on the driver, the tank is on the driver, the fuel lines on the driver and the filter is on the driver side. Mine is a 1500 ext cab 5.3. What is the make that has the passenger side filter?
Cam in and
Check out my Ride
Old 03-18-2005, 06:34 PM
84fiero123's Avatar
84fiero123 84fiero123 is offline
open drivers door look at the outer edge of the door, the place where the latch mechanism is, at about eye level you should see a label that says made in usa by uaw and what plant. as far as depresurizing the lines if you have throttle body you don't need to it depressurizes the lines when you shut truck off. only the type with real fuel injection needs to be releaved but for a fuel filter its not worth it.
technology is great when it works
but one big pain in the ass when it doesn't
Detroit Iron Rules, all the rest are just toys!
