Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 12-06-2004, 07:44 AM
vinsalor vinsalor is offline
Banned
Change Engine Head Good Idea?
hi i have a civic 91 sedan eg and my engine is a d15b7 carbby, my idea is just to change the head(block) to a d15b vtec or a d16 is dis a good idea because i only have a budget of AU$1000.thx for future answers
PS. Is der a d15b vtec carbby??Kinda lost on dat one
Old 12-06-2004, 03:37 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: Change Engine Head Good Idea?
no it isnt its an efi setup and the cost of the conversion would not be beneficial, due to all the extra wiring, ecu, etc that would be needed.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-06-2004, 03:38 PM
Milliardo's Avatar
Milliardo Milliardo is offline
Send a message via AIM to Milliardo Send a message via Yahoo to Milliardo
Lightbulb
I don't think there's ever a VTEC engine that's carb, so the D15B VTEC isn't carb. As for changing heads--know first what your goals are. You just don't change heads and expect to drive off. Or rather, you just don't change anything on your motor if you don't have any goals in mind. What would your car be--daily driven, for race/strp, combi daily drive/strip? Depends really what you'd like your car to be. Next off is of course to research--know what you want to put in and read up on those. It will take much guesswork off, plus give you some more knowledge about your car.
Admin of PGamers Forum
1993 Honda Civic ESi (Sailor Mars)
My wish list--I need help in this project: http://pikarod.fateback.com/car3.html
Old 12-06-2004, 06:37 PM
Banned
thx guys for the prompt reply!well i heard that efi is better than carby due to better power (dats wat i heard).And my goal wif my car is jas to get enough hp to keep up with my friends (silvia,180,integra) and my d15 engine i cant get enough hp so a vtec should kinda minimise my problem.i heard i can do a ls/vtec conversion.is dat a good idea?if so i heard if i floor the car too much it could blow the engine.true?
Old 12-06-2004, 07:18 PM
swaptrex swaptrex is offline
Re: Re: Change Engine Head Good Idea?
ehhh?? u can't do an ls/vtec w/ a d15 block. u will first have to swap in a ls block than retrieve a b-series head, tranny, ecu, etc. its not a simple bolt-on process!! and yes u can blow your motor if u give it to much throttle over time and also ur tranny if u don't shift gears!!
Old 12-06-2004, 10:36 PM
Banned
so wat would be a good suggestion?keep my engine as is? or upgrade it to wat type? preferably VTEC engine.. not interested in whole engine swap jas block/head swap thanks
Old 12-06-2004, 11:01 PM
Milliardo's Avatar
Lightbulb
I would rather that you do the whole swap just for starters rather than a mini me. A good bet, like I stated before, would be the JDM D15B, which is a VTEC engine and is quite mean for a 1500 engine. Just make sure you have the right ECU for it (either P08 or P28) to make it run right. Had mine installed, but the POS of a shop that made the swap used my stock ECU (P27) instead of the ECU that goes with it, so now I have to find a P08 ECU (they even sent me the wrong ECU, which is a P07 automatic, when my engine's for manual transmission). Dumbass of a shop.
Old 12-06-2004, 11:56 PM
Banned
hahah shit bad luck man.should of complaint to em.since i live in australia (melbourne) i duno which shop to ask bcoz most have non vtec engines.also im in a tight budget so a mini me would really suit me atm.A whole engine swap will really kill me financially.wat is the up and downs on a mini d15b vtech??if so can i fit a b16 block only with stock harness of mine?
Old 12-07-2004, 03:30 AM
Banned
Also is it possible to put vtec kit into my engine as the only intention i want is a vtec engine!
Old 12-07-2004, 06:59 PM
crxlvr's Avatar
no you cant just add vtec to a motor. VTEC is a combination of sensors and valvetrain components designed for both low end economy and high rpm power. it cannot be added onto anything, the motor would have to have had the vtec already on it.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
