Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-05-2004, 11:41 PM
WestCoastSailor WestCoastSailor is offline
'04 Silverado 4x4 LS/what will fit??
I'm thinking about getting larger tires and wheels with the appropriate width to go with them. Stock is 245/75/16. I would like to go to 285/75/16 on 16x8 wheels without having to do any kind of lift. If this won't work, maybe 265/75/16 on those same 16x8 wheels. Can someone point me in the right direction? Thanks
Old 12-06-2004, 12:53 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: '04 Silverado 4x4 LS/what will fit??
you can probably fit 265's on your stock wheel
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-07-2004, 12:14 PM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
A 275/70-16 is the largest we have test fit without a lift kit.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 12-17-2004, 11:21 AM
Grant- is that wider or larger diameter. 'cause a 265/75(also available on Silverado) has a larger diameter and a 285/75 is only a hair wider than the 275/70. Anyhow, I've got my 16x8 wheels now, and went to a local tire shop and they measured and said that the 285/75 would fit okay. Which is great, but are they blowing smoke up my a**, because now I would worry about suspension play. Decisions, decisions!!
