Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 03-01-2002, 02:13 PM
tim-may's Avatar
tim-may tim-may is offline
Send a message via AIM to tim-may
HELP Tranny Guru's!! Tranny pan is off as we speak!!
Confuscious say:
"Sum-bitch .. how does one remove the valve body from the case in order that he may remove the filter, eh?"
A notice that came w/ the filter kit says I must drop the valve body first cuz If the filter and bolt are removed without first removing the valve body, then the reamer bolt will not screw back in because the nut is displaced. The valve body appears to have several bolts holding itself together and to the trans which ones am I to remove? Would I be better off buying a Chiltons manual or something?
Tim Smith
- Sony Xplod CD receiver
- 6.5" Fosgate Fanatic component system (front - doors modified)
- 6.5" Infiniti Kappa's (rear deck)
- (2) 12" Fosgate XLC's
- Fosgate Punch 360a 2-channel (subs only)
- Modified stock air box (better sound -- that's about all though)
ooohh, six mods..
