Old 12-05-2004, 09:17 PM
CRX-Crooks's Avatar
CRX-Crooks CRX-Crooks is offline
Send a message via MSN to CRX-Crooks
What Engines Will Fit
Hey I was woundering which single over head came engines will fit in my 1990 honda crx dx and how much will it cost? Which single over head cam engine do you recomend? Thank You.
Old 12-05-2004, 10:13 PM
clawhammer's Avatar
clawhammer clawhammer is offline
Re: What Engines Will Fit
If you're going through the trouble of swapping, you might as well get a B16, DOHC Vtec for about $1200 for the engine.
Old 12-05-2004, 10:34 PM
forcefanad forcefanad is offline
Re: Re: What Engines Will Fit
he said SOHC....apparently he has plans of some sort or doesnt want to go through the hassles of making shift linkage and buying mounts, id say if u want to go SOHC then go d16z6 or d16y8....theres a lot of after market support for these motors and they dont mind a lil boost either.
Old 12-05-2004, 11:07 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
would a d16a6 be nice to use? that's what i have and wondering if i should swap it out of not. MPFI and everything already, and 202k miles. Not sure if i wanna do something with that used of an engine
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 12-05-2004, 11:12 PM
Kven's Avatar
Kven Kven is offline
f22! i would pick either d16z6 or y8. d16a6 is nonvtec.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 12-05-2004, 11:40 PM
honda_luvr_2000 honda_luvr_2000 is offline
to put it simply, any honda motor will fit. as for SOHC, any D-series will bolt right in w/ u'r stock mounts, and mate right to u'r existing tranny. as others recomended, the D16y8 will be a good canidate. however, as another said the D16A6 would prolly be u'r best bang for the buck, unless u find a sweet deal on a D16y8 setup. The D16A6 has damn near just as many aftermarket options as the D16Y8, so it's up to what u'r end goal is.
www.nippon-motors.com has D16A6 for like $395, then a ECU would be around $50 depending where u look. their D16Z6 (basicly a D16Y8) is running $650
Old 12-06-2004, 12:22 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
d16z6 or d16y8 would be the best sohc setup
Team Lonely Drivers
Old 12-06-2004, 04:41 AM
Integrity1's Avatar
Integrity1 Integrity1 is offline
yeah z6 or y8
Old 12-06-2004, 10:37 AM
ef four door's Avatar
ef four door ef four door is offline
SOHC ZC! It's not too expensive (around $350), you dont have to wire for vtec, and its almost a good as a DOHC ZC. Look at my sig.
1989 civic lx four door, MPFI SOHC ZC powered, SOLD
1988 civic dx four door, D15B VTEC...permanently converted to obd1
Old 12-06-2004, 11:31 AM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Almost as good?
The DOHC can run 14 seconds with a good driver...
Your sig says you run 16 seconds. Even with a 14.9 vs your 16.1 thats more than a whole second.
Not to flame but.... the DOHC ZC is way better.
Travis
Old 12-06-2004, 10:01 PM
the ones ive seen run mid 15s at best...
Old 12-06-2004, 10:03 PM
anthony90si anthony90si is offline
depend on what is done to the car. weight plays a big role. dx cx si i seen stock si doing high 15.
Old 12-07-2004, 12:34 AM
Beater88 Beater88 is offline
Easy and cheap:
d16a6 (108hp)
SOHC ZC (115hp)
Better but harder (more expensive):
d16z6 or y8 (125hp)
DOHC ZC (137hp)
d15b VTEC (not as good a z6, but cheap) (120hp)
Very hard (very expensive):
Any integra
b16
Dont Try:
d16a1
k-motors
H-motors
Old 12-07-2004, 12:35 AM
CRX VTEC TURBO CRX VTEC TURBO is offline
Go with the d16z6, they fit real nicely in the car..almost as if it was stock. plus, besides this, it is a good engine to buy parts for and to build off of....it might not produce as much power as your b16s and such, but it does good work for the sohc. the Y8 is rather similar to the z6, but in my efforts with a friend of mine I had trouble locating engines of that nature. the z6 is in all civic ex's or si's from 92-95 i believe.
Old 12-07-2004, 12:39 AM
