Old 12-05-2004, 09:14 PM
96cavi 96cavi is offline
Send a message via AIM to 96cavi
fuel pump relay
does anyone know how to swap fuel pump relays?? how hard is it and how would i go about doing it.. thanks
Old 12-05-2004, 10:26 PM
OverBoardProject OverBoardProject is offline
Banned
Re: fuel pump relay
just like a plug, I believe under the hood on most chevy's although your owners manual will tell you for sure.
those relays just burn out like a light bulb, so if your having a problem it's probably wiring, or the fuel pump it's self
Old 12-06-2004, 04:12 PM
Fractured1 Fractured1 is offline
I know on my 96 it's in the glove box...
Old 12-07-2004, 09:33 PM
Re: fuel pump relay
does anyone know where the fuel pump relay is in an 88 s10?
thanks
Old 12-11-2004, 08:13 PM
general poot general poot is offline
Re: Re: fuel pump relay
thanks
I beleive it is on top of the drivers side wheel well. It is a small black square box with a plug in harness. There is probably two relays beside each other, it will be the rear one. Good Luck!
Old 12-11-2004, 09:13 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: fuel pump relay
drivers side on firewall right behind or just to the right of mastercylinder
Old 12-12-2004, 02:41 PM
xtremetrk xtremetrk is offline
Re: fuel pump relay
Ya its as easy as switching out a fuse. It's in the fuse box under the hood. on my 99 s-10 it's on the drivers side but on an 88 the fuse box under the hood could be somewhere else.
