Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-05-2004, 09:02 PM
Feint Motion's Avatar
Feint Motion Feint Motion is offline
Exclamation Curve FairLady Z33 (350Z) ~Ultimate Bodywork~
Since the contest was a fluk, I plan to do one Project Next year, Curve's Z33. ( http://www.curve-ad.com/z33/index.html ) I've had a some other cars in mind, but the 350z is just so unique. Its going to be a challenge; 3 types of putty, 8 kinds of files, & a Dremel should get the job done.(year right )I've done bodywork before, no problems in that area.
Here are some photos in progress (1:1)
Aint she a bute? And in its only progress..
Finished product here: http://www.curve-ad.com/z33/photo_as.html
1st thing I will have to do is purchase a Masito 350Z or an Hotwheels 350z.
So I guess this is sort of an intro to my year long build.
Expect some progress around January.
Thanks for looking! Wish me luck.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Old 12-05-2004, 10:10 PM
Rubberband Man's Avatar
Rubberband Man Rubberband Man is offline
Send a message via AIM to Rubberband Man
Re: Curve FairLady Z33 (350Z) ~Ultimate Bodywork~
That is awesome, good luck
Old 12-05-2004, 10:52 PM
tytgs300's Avatar
tytgs300 tytgs300 is offline
Kia ?
Old 12-06-2004, 12:06 AM
Autobaas Autobaas is offline
Send a message via MSN to Autobaas
Good Luck, you need it
Old 12-06-2004, 07:50 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Josh. That is going to be damn sweet! Awesome selection for a build, and I know you are one of the few that can pull it off correctly. I do think that car made the bondo stocks skyrocket though.
I do suggest making the base out of styrene and trying to use as little putty as possible. If you go into car modeling, Kunta is building a pantera. All of his boddy work was done in styrene, and he posts great progress if you need ideas.
Good luck, and finish it. Otherwise you will get some Tamiya Ritalin.
-Mike
Old 12-06-2004, 02:42 PM
bkvj's Avatar
bkvj bkvj is offline
Send a message via MSN to bkvj
sweet...cant wait too see pictures
Old 12-06-2004, 07:53 PM
Hobbes's Avatar
Hobbes Hobbes is offline
The unusual suspect
Looks like it's gonna have a good turnout. Best of luck to you.
Old 12-06-2004, 09:30 PM
Re: Re: Curve FairLady Z33 (350Z) ~Ultimate Bodywork~
Yea i think that car did make bondo's stock go up..
Thanks for the tip, I planed on using a styrene skeleton from the start. (putty is getting expensive, 10.50 a pop). I seen some of Kunta's work, pretty damn impressive , I will most def look at some of his past builds to gain some more technique/tips.
Thanks for the comments, 1st set of progress will be pictures of the materials I will be using.
~Josh~
Old 12-07-2004, 07:48 AM
mike@af's Avatar
Re: Re: Re: Curve FairLady Z33 (350Z) ~Ultimate Bodywork~
I was using more and more of it, then started going for pure styrene...saved the wallet, thats for sure.
-Mike
Old 12-08-2004, 06:30 AM
GvEman's Avatar
GvEman GvEman is offline
looks sweet! i hope your model turns out as god as the real deal.
Best Regards
Anton
Old 02-13-2005, 09:10 PM
SkylineMan32
Guest
Posts: n/a
I like it!
Old 02-13-2005, 10:22 PM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
Originally Posted by SkylineMan32
I like it!
This thread is 2 months old and you've been here over 6 months, haven't you learned to not dig up the corpses of old threads?
Old 02-14-2005, 12:20 AM
nosliw2004's Avatar
nosliw2004 nosliw2004 is offline
Send a message via AIM to nosliw2004 Send a message via Yahoo to nosliw2004
gafoto is right
Closed Thread
