Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-05-2004, 08:51 PM
Sn00man Sn00man is offline
bad oil leak?????????????
hey
got a problem,1995 gc,4 lire,bad oil leak at the fly wheel,l have pulled the pan and changed the cranks seal and also the oil pan gasket,still leaks,pulled the pan second time checking for the gasket out of place put back together still leaks any ideas out there,thanks and help drive way looking bad
Old 12-06-2004, 06:27 AM
Cam7 Cam7 is offline
if you change the rear main seal and it still leaks wipe off the back of the motor have to crawl under when its running to see if it is leaking from the rear main or if it is comming from the intake or vale covers. If it is comming from the rear main you will have to replace them again. This time add some silicone to the end of the seals before bolting the cap on.
Old 12-06-2004, 07:41 AM
Re: bad oil leak?????????????
thanks l will try it again,l guess l should use new seal and gasket again,thanks again for the reply
