First Mod...
gonna add an Injen intake for my first mod i know the MAF has to to go on the Air Intake but there are like 3-4 different sprites(hoses) coming off the stock air intake and on the injen one i believe there is only one sprite?...what else needs to be done besides attach intake to throttle body and MAF to end and connect Filter to MAF?
attach one hose, the one going to the valve cover and they plug the others with bolts or plugs
is this an Injen intake? i bet most are the same but they plug the others up with bolts? you mean like take a Bolt and screw it into the previous outlet?
Re: First Mod...
The larger one coming off of the intake manifold(about 2 inches to the right of the throttle body)and connecting to the stock intake has to be connected. This is your idle control hose. Without it, your car will not idle(DUH??lol). The smaller one is for the carbon canister which you don't need. Connect it up if there is a barb for it though. I'm pretty sure there should be more "Sprites" on the intake. Have you recieved it yet?
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
no but..
No but the pictures prob showed a diffenrent Application so that will probably set my mind at rest now ive got another problem which i hope isnt expensive
