Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 12-05-2004, 06:50 PM
iamlucas iamlucas is offline
91 b2600i, brake indicator light on
I recently purchased a 91 b2600i, and the parking brake light started coming on. At first, it would flicker on, then go off while driving, but now it stays lighted all the times. The emergency brake is NOT engaged. Has anyone else experienced this problem? Would the cable between the emergency brake and the light need replacing?
thanks,
Lucas
Old 12-06-2004, 10:30 PM
kentuckyboy23 kentuckyboy23 is offline
Arrow yeah
my truck had the same problem so i just unhooked the light because i thought it was a short. it would flicker when i hit a bump or the gas and would just go off.
Old 12-10-2004, 03:13 PM
harritwo harritwo is offline
Brake light
There is a switch on the parking brake assy, that is held in by a piece of plastic, this is probably broken due to age, replace it or unplug it and light is off.
Old 01-20-2005, 01:48 PM
jdusablon jdusablon is offline
Re: 91 b2600i, brake indicator light on
thanks,
Lucas
I had the same problem, and I thought it was the parking brake on/off sensor. It's not.
The brake fluid container in the engine compartment contains a sensor float that turns the light on when the fluid is low. I just topped it off and the brake light went away. Now it only come on when I use parking brake.
This also explains the flicker, since the float sensor is more prone to movement during travel. Also, you should never disconnnect the light to the sensor! These lights have more than one meaning...in this case you could lose all your brake fluid and never know!
