Old 12-05-2004, 06:16 PM
Knight2040's Avatar
Knight2040 Knight2040 is offline
Send a message via AIM to Knight2040
Sunroof questions
Alirght first off, is the sunroof in the below pic stock? second question is it compleately removable and can it just tilt the rear? also, does this eliminate the center dome light and visors? now if this is stock could i just go to mitsubishi and order the glass panel and have a body shop cut it out for me? Did thease models have extra support bars? thanks guys
1991 Mitsubishi 3000GT VR4 Twin Turbo- Forged Ross Pistons,Forged Crank,Forged and Shotpeened Rods,Stillin DP,K&N FIPK,Greddy Type-RS BOV,Magnacor Wires,Aluminum Y-Pipe,EGR Blocked,All Gutted Cats,Greddy Turbo Timer,Blitz Boost Guage,Autometer A\F Guage,Solid Shift Bushings,Red Top Batt,ACT 6 Puck Clutch,Free Boost Mod,99 Front End Conversion
Old 12-05-2004, 06:25 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Sunroof questions
stock yes, can you just order the panel no. Dome light and visors are intact. its completely removable, but there is about a 3-4 inch lip under the glass that stays where its at, so the hole in the top isnt the size of the glass that is removed.
You could find a wrecked car and have a body shop cut the cop of it off and weld it to your car.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-05-2004, 06:36 PM
Knight2040's Avatar
what's diffrent that won't make it directly compatible?
Old 12-05-2004, 11:50 PM
InfestedShadow InfestedShadow is offline
Send a message via MSN to InfestedShadow Send a message via Yahoo to InfestedShadow
I need infos on this blue 3000gt, that's exactly what i'm looking for.
which model can have a sunroof like this one ? ( well, what I want is a removable toplike this one, but fiber glass instead )
Old 12-06-2004, 12:21 AM
because there are mounting points for the sunroof thatyou dont have.
they were avalible on 91-95.5 sl and vr4, maybe the base
Old 12-06-2004, 12:47 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Sunroof questions
The roof assembly is completely different as talskinyguy stated. You cant just cut the roof of a non sunroof 3s and make the large removable sunroof as pictured fit. If you want that sunroof you would have to do the work of cutting out your roof and having that roof cut out of a donor car and put in place. I sold a complete roof assembly like that earlier this year to someone looking to do the same swap.
They were an option for all 3/s's in the years stated by talskinyguy. The one I sold came from a base Stealth.
Talskinyguy basically covered everything. I am just verifiying what he said is right. And BTW that roof assembly I sold I beleive is for sale again. The guy I sold it to had issues with his car and never go the swap completed. His name is KTMryan53 over on 3si. He may still have it up for sale.
Old 12-06-2004, 01:35 PM
so if I want to add a sunroof on my car, i'll have to go at the car dealer and ask them to add one on my car ? and I have to bring myself the sunroof kit
Old 12-06-2004, 02:22 PM
Igovert500's Avatar
blue + red light magnet
Most if not all dealership wont do that swap for you...and there is no 'kit'. As was said before you need an entire roof w/ sunroof chopped of a 3000gt that originally had one, and then take it to a body shop. They will chop your roof off and mount that other one on in it's place. This isn't exactly a cheap/ordinary swap that a dealership could do.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-06-2004, 03:47 PM
alright thx for the infos bro
Old 12-06-2004, 06:12 PM
Knight2040's Avatar
but can't delaerships install "factory" sunroofs or do they only do that when your buying a new car.
Old 12-06-2004, 06:43 PM
jdridah jdridah is offline
Has anyone or know anyone that has had a T-top installed? what kinda price would i be looking at on a 94 base.
__________________________________________________________
Old 12-06-2004, 07:03 PM
the only thing i've see is moonroof.
Old 12-06-2004, 07:19 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Dude the pic above is of a sunroof. 3SX sells CF nes also so they definately exsist. http://www.3sxperformance.com/body.asp 60% of the way down.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-06-2004, 08:57 PM
Stealthee's Avatar
The roof of a non sun roof car can in no way possible be made to work with the factory style sunroof. They are 100% different. Its going to be a custom job no matter what. You need a roof from a sunroof car if you want a factory sunroof. ANd the dealer is not going to perform such a surgery on your body. Its something that will have to go to some kind of body shop if you yourself dont have the skills.
Mitsu actually didnt even install the factory sunroofs themselves. Once the cars were imported certain ones were designated as to have the sunroofs. Those cars were sent to a manufacture who swapped the roof assemblies. Same basic thing as the spyders. Once they came inland they were sent off to a seperate factory to have the "conversion" done.
As for T-tops, its going to be 100% custom so I would guess you are looking at $2000 or better to have something fabbed up.
Old 12-06-2004, 09:39 PM
Thourun's Avatar
It'd probably be better to just make it a spyder.
1995 3000GT VR-4
