Front plate bracket
Does anyone know if there is a front license plate bracket made for a 2005 Silverado Z71. The front airdam peice sticks out and makes the plate sit on a angle, Looks Bad!
Mike |
I'm also in the same boat, called local dealership and the said they had no part for chevy '05. If anyone knows about one it would be appreciated.
Re: Front plate bracket
try for an 04 itd be the same.....BUT i dont think they make one...check this out.....: http://www.carr.com/lightwing.html
looks like that would solve your woes and give you a fog light mounting spot if you needed...or wanted
![]() '99 Silverado 4 x 4 bunch of goodies |
Tthanks for the quick reply, but I think that one is just a bit more then i'm looking for. Just something simple to hold the plate so it doesnt have to bend around the plastic and scrape up the chrome. Chevy really overlooked this if there is no part for this, seems lacking in the planning dept.
I got one at advance auto parts... it's a universal design with 3 mounting positions, and I mounted it sort of above the airdam, nearly flush with the top of the bumper. Maybe you can tell in my sig. It actually has a higher mounting position available, but mine is mounted in the middle position.
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
The guys on another forum found one at GM Accessories. Front License Plate Frame Kit, P/N 12496895.
http://www.gmgoodwrench.com/accessor...eName=Exterior |
Edit BTW heres a pic of my new truck. woohoo.
Re: Re: Front plate bracket
Thanks for all the help guys. And thanks for the link and part number 93stocker, much appreciated. I'll be on my way to my dealership that just told me theres no such part with the part number tommorow. =)
Thanks, after I went and painted the bumper, painted the valances, and cut out a black craft foam to keep the plate from scratching the new paint and NOW you tell me that there is a bracket that looks correct???
Thanks Thanks.....
![]() "The Sleeper" '05 6.0L VHO Cam in and Low 14's happening at the track ![]() Check out my Ride |
