Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 12-05-2004, 05:20 PM
synonim synonim is offline
Power Seat-belts getting stuck on track
Just got a '94 ford tempo GL with power seat belts and i need the seat belts fully functional before i am allowed to drive it and they keep getting stuck on the big curve of the track and then make a grinding sound, but if i help them alot they go, how do i fix for cheap, please help and thanks.
Old 12-05-2004, 05:24 PM
Shawn Snipes Shawn Snipes is offline
Re: Power Seat-belts getting stuck on track
well i know who tha fells trying to fix stuff for cheap, most of the time cheap fixes and up breaking, but on this subject i don't know maybe others will have luck helping you
Old 01-11-2005, 05:31 AM
hain84's Avatar
hain84 hain84 is offline
I used to have a 89 t-bird and it had the auto seat belts too. i told a friend about it and he fixed it for me kinda. he shut the door where the seat belt is in the on position and he took out the fuse or unhooked it from the track any way i didnt have to worry bout any more and im not sure what he actually did.
'99 Taurus 3.0L 12v Vulcan
http://www.adams.net/~woll
Old 02-12-2005, 08:30 PM
escort0526 escort0526 is offline
...and now for a coherent response. The Tempo seat belts run on a plastic track that binds up as the casing cracks with age. This is the likely cause of your problem. The only way to fix it and make it work as intended from the factory is to replace the track which is about $75.00 each from a salvage yard. You can, if you like, unplug the motor,it's in the door pillar on sedans and next to the rear seat passengers on two doors. This isn't an official fix, but it will lock them in position and you'll have to operate them manually. If they're the kind without a release as some tempo's were you'll have to spring for the salvage yard fix to make them legal.
