Old 03-01-2002, 12:02 PM
Rtypespekz10 Rtypespekz10 is offline
Question rear drum to dic conversion
I got a 97 Accord se and im wondering if i can swap out my rear drums for discs? What parts do i need and from what car? Also, does ne1 know where i can get a carbon fiber front lip and type r grill?
Old 03-01-2002, 12:35 PM
92AccordCoupe's Avatar
92AccordCoupe 92AccordCoupe is offline
Send a message via ICQ to 92AccordCoupe Send a message via AIM to 92AccordCoupe Send a message via Yahoo to 92AccordCoupe
i've only seen disc brake conversion kits for civics. i don't know how fessible (or advisable) it would be to just replace the drum parts with the disc parts...you can call your local honda dealership and ask them.
also, i thought a 97 se would come with rear discs??? isn't the se supposed to be one level higher than the ex (it does stand for special edition)?
"We spent a lot of time talking about Africa, as we should. Africa is a nation that suffers from incredible disease." -- George W. Bush :right:
Old 03-01-2002, 01:12 PM
twizzaut's Avatar
twizzaut twizzaut is offline
this gut i know did it to his 4th gen accord. nice as hell!!! but from what ive heard hes had brake problems after he got it done
HöÑÐã§ 4 Lïƒê
Old 03-01-2002, 09:42 PM
mike89lxi's Avatar
mike89lxi mike89lxi is offline
i plan on doing the rear disc conversion on my 89 accord. the 88-89 accord se-i's came stock with rear disc brakes and they will swap right onto my lx-i. one more reason to own a 3rd gen!
Old 03-02-2002, 07:05 PM
VTECseoul VTECseoul is offline
Send a message via AIM to VTECseoul
the SE model is 1/2 way from LX to EX...it comes with some EX options w/ LX parts. ie, ABS, sunroof, wooden dash...
you need whole new suspension parts cuz they go w/ the brake system; from a 97 EX model w/ rear discs. check your local junkyard & look; do the research. or get a performance shop to rip you off, i mean do it. it's a lotta labor & parts may be expensive to get.
2000 Honda Accord LX Satin Silver Sedan
AEM ColdAirIntake
Neuspeed Sport Springs
Nitto 450 225/50
Prime Racing M8 17x7
S15 vs AE86 - 2006 HotWheels Touge
Old 03-29-2004, 03:42 PM
nk4k nk4k is offline
brake problems
can you say exactly what type of brake problems your friend had after converting his 4th gen. to rear disc?
Old 03-30-2004, 12:10 AM
92lx 92lx is offline
Re: rear drum to dic conversion
easily done, just swap the rear suspension, e-brake cables, and make sure you use the proportioning valve from the disk-brake equipped car. Otherwise, it bolts up perfectly .
- Nathan
Old 03-30-2004, 01:42 AM
SenseiAccord SenseiAccord is offline
IMO, converting to rear disc isnt worth it. It will cost money and it doesnt improve braking all that much. Just get some power slots for the front or brembo cross drilled and it will improve stopping the same as the conversion without the big money.
Old 04-01-2004, 10:13 AM
cknotts01 cknotts01 is offline
I agree with the above thread... it probably isn't worth it. I was considering doing it since I just had the entire hub/suspension assemble off this weekend while installing the Eibach Pro Kit. That was a mess, but luckily it happened on the last corner, or I would have quit. I broke the damper to knuckle bolt, broke off an easy out in the bolt and couldn't get it to budge... I had to take the entire thing off to have a friend's dad press it out. Anyway, back to the topic at hand... you also have to get a new master cylinder. If you find a junk car at a yard with discs on the rear just get the cylinder off of it.
I am just going to paint the drums and put slots on the front... yeah I know... the easy way out.
Let us know what you do!
Old 04-01-2004, 11:36 AM
but rear discs make e-brake response so much quicker!
I think I might look a little more into a conversion.
Old 04-01-2004, 01:52 PM
Thumbs up Re: rear drum to dic conversion
Odd that you say that because the write-up that I read did not even install the e-brake. I was wondering about that. If I can find the story I will post it on here. You do have a point
Old 04-01-2004, 02:01 PM
Ok.. how dumb of me... I just turned around and found the mag. Check out the new Honda Tuning mag. They did it on 94 Lx with no mention of the e-brake
Old 04-02-2004, 01:42 AM
u gonna be drifting or something? u can just adjust the e-brake to make it respond better. I would think drums would respond faster since they are more prone to lock up. Anyway honestly it isnt worth it. Even if u are gonna drift... ur car is FWD. Your car is gonna be understeering too much.... thats why it isnt an ideal drift car (FWD cars).
Old 04-03-2004, 07:55 PM
drifting
No, I don't plan on using my accord lx as a drift car.
I just like to scare the people in the back seat. I was mainly going to do it for asthetics, but I think you talked me out of it.
(too much work)
