Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 12-05-2004, 04:52 PM
buddyjohn buddyjohn is offline
99 corolla
Working on my daughters toyota. Having some problems. Car initially turns over then very rough idle and stalls. Already replaced the fuel pump. I have fuel at the injectors, pulsating when turned over. Read in the pump instructions that if car did not start it could be a bad oil pressure relay. Is the true? Also, I know it's dangers, but I sprayed ether down the carb, and it runs very well and smooth until I stop spraying, then It rough Idles and stops. Whats up? Also where is the fuel filter and or fuel regulator.
Any help is appreciated.
Old 02-07-2005, 04:52 PM
firedrewski03 firedrewski03 is offline
Re: 99 corolla
Fuel filter is on firewall in the center if the vehicle. Silver, cant miss it.
Old 09-15-2005, 11:25 AM
edbert edbert is offline
Re: 99 corolla
Actually the fuel filter is part of the fuel pump itself. Mine gave out after about 120K this past spring.
