Old 12-05-2004, 04:32 PM
sellj75 sellj75 is offline
95 Grand Am Overheating
I have a 95 Grand Am that is overheating. It will get hot super fast at an idle, and will only cool down when accelerating . We have changed the water pump, thermostat, flushed and changed the tank to the radiator (it had a small crack), also chagned the fan, and the temp sensor. Anybody have any ideas on what else it could be?
Old 12-07-2004, 10:38 AM
docmidnite docmidnite is offline
Re: 95 Grand Am Overheating
I have the same problem man. With 95 2.3L Quad 4...have you figurd it out yet?
Old 12-16-2004, 02:05 PM
No, still have not figured it out.
Old 12-20-2004, 08:52 AM
johnman330 johnman330 is offline
Re: Re: 95 Grand Am Overheating
Try the thermostatic switch. It controls when the cooling fan kicks on. If you replaced everything else, i would check that. Also most GM cars radiator fans will kick on when the A/c is on. Try turning on your A/C and see if your fans work. Good luck.
Old 01-01-2005, 07:02 PM
Dima7700 Dima7700 is offline
hey man i've got a 95 Grand am with "genious" Quad 4 in it, it did the same thing when i juss got it. the reason y it overheats cuz it's gms fault, they made crapy water pumps, u can change 10 of em, won't change a thing, the thign that helped me was to flush radiator, since then i didn't have any problems, unless i let car idle for a long time, then u juss need to drive and will cool down. good luck my friend.
