Old 12-05-2004, 04:14 PM
sykotic1 sykotic1 is offline
Question Heater Problems
1991 z28 305 tpi having some heater/AC problems. For a while everything was fine, then periodically none of the controls would blow any air at all, heat or not (this happened every now and then, sometimes it would work fine). Now whatever blows the air seems to have died completely. I'm only really worried about the heat at the moment but I'm not sure if the heater core would be the problem if nothing happens at all when I try to turn it on. I've checked fuses, everythings fine. Anyone have an idea where I could start? Is there a blower switch I could check? What would actually be blowing the air? I really appreciate any help.
Old 12-05-2004, 04:51 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Heater Problems
sounds more like a blower motor failed. do you hear it running? and just cant feel the air? or does nothing at all happen?
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 12-05-2004, 05:51 PM
Re: Re: Heater Problems
nothing happens at all. any idea where i can find this thing? i'll fix it myself if it isn't too buried.
Old 12-06-2004, 02:42 AM
89IROC&RS's Avatar
Re: Heater Problems
lol, to be honest, im not 100% sure where the blower motor is on the third gens, it should be under the dash on the passenger side, you should be able to get to it from the bottom.
Old 12-06-2004, 08:29 AM
boosz28 boosz28 is offline
I may be wrong but i do believe the blower motor is on the far left( if looking with hood open) on the passenger side under the hood
Old 12-12-2004, 11:10 AM
NINÅ's Avatar
NINÅ NINÅ is offline
Hot Subject
It's where boosz28 said. No it's not buried. It's an easy job, but for the bottom screw have handy a flexible extension. Before removing make certain it is the problem by jumping 12 volts to it.
REFUSE
· TO · LOSE
