Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-05-2004, 02:00 PM
eclipse2quick21 eclipse2quick21 is offline
tranny or clutch problem?
ok, when my car is running and idling, with the clutch down, it will absolutely not go in any gear. but when the car is shut off, it will go through all the gears without any problem. this is with a 96 teg LS manual tranny. i really need to know what is going on here. thanks in advance.
Old 12-05-2004, 03:07 PM
integralover's Avatar
integralover integralover is offline
with the car running and you push in the clutch and it will not go into gear, that is a clutch prob. when the car is off you should be able to shift into almost any gear. that is when the main shaft is not spinning so the syncro's do not have to work to go into gear. i hate to say but you need a new clutch
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 12-06-2004, 02:25 AM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
Re: tranny or clutch problem?
yeah i had the same prob before. took it apart and looked like a grenade went off on the clutch disc. get a new clutch should be an easy fix
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
Old 12-06-2004, 04:08 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
its your clutch jigga...
had same problem in my gsr, and the ACT XTSS fixed it quickly.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 12-06-2004, 09:09 AM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Yep go with the ACT
Old 12-06-2004, 03:48 PM
how would a exedy stage 1 clutch hold up with an ACT streetlite flywheel? this is the setup that fits my pricerange a little better, and want to know how it will do.
Old 12-06-2004, 07:02 PM
exedy and act both a pretty good companies. not a bad combo
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 12-07-2004, 11:09 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
since its so easy to check but easy to not think to check. check your hydro fluid levels because i had a friend that thought is clutch went out it wouldnt go into gear and it ended up just being his hydro fluid was bone dry.
Keep it real, and share the knowledge.....
Say NO to Primer!!
