Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 12-05-2004, 11:38 AM
fmrmti fmrmti is offline
High Engine Temp
I know that Jeep engines are supposed to run hot (195°-210°), but I don't like it. Has anyone put a cooler thermostat in? What (long-term) results?
97 TJ
Old 12-05-2004, 12:05 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: High Engine Temp
They run best at those temps. That is what there made to run at. I personally would not mess with it.
You could put in a cooler thermostat, but you could loose some power. Most of your power will be around 200-210 Degrees
Old 12-06-2004, 09:29 AM
K4A K4A is offline
Modern engines have electronic controls that are based on the fuel/air mixtures, engine speed and coolant temperature. If you arbitrarily change these parameters poorer performance is usually the result. Engine temperature also affects proper lubrication within the engine. Run too cool and premature wear will occur. Get over the "I don't like it" phrase and realize you are not an automotive engineer, but simply an owner that should probably heed the manufacturers advice.
Old 01-26-2005, 08:28 PM
rob j rob j is offline
Factory specs call for a 195 degree thermostat, I would stick with that. The computer takes info from the coolant temp. sensor, and makes adjustments accordingly.
