Old 12-05-2004, 12:09 PM
axenios axenios is offline
remove ignition tumbler
Hello, I have a 1995 Jeep Cherokee "Country" and am having problems with the ignition. It starts, but when I release the key to the normal operating position, it kills the engine. If I prevent the key from returning to it's resting position, it stays running.
I want to remove the tumbler and key to see if it needs replacing, but I don't know how. Can anyone help me? Thanks....
Old 12-08-2004, 01:45 PM
89ltd 89ltd is offline
If it is the same type of ingnition switch as the 89, it is lower down on the steering colum and is activated by a rod leading down from the key cylinder. The switch it self down the colum is adjustable, there are slots and should be adjusted before you tighten it up.
Old 12-08-2004, 03:49 PM
Dale Aeppli Dale Aeppli is offline
Re: remove ignition tumbler
Did you change the ignitiom switch itself the one at the bottom of steering column. If you did , did you adjust it before connecting it up? Dale [email protected]
