Old 12-05-2004, 09:28 AM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
Unhappy Stubborn O2 sensor (front)
I have been trying for 5 days to change my front o2 sensor (2000 s-10 2.2L code 4engine) .... i have tried heating it, PB Powerblast, and just yanking on that bitch. i was told that i should have entire exhaust system replaced, or drill a hole below the original sensor and bypass it! any suggestions!!???
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 12-05-2004, 09:42 AM
Mikado14 Mikado14 is offline
Re: Stubborn O2 sensor (front)
Is the sensor still intact? What type of wrench are you using? Where did you heat?
Old 12-05-2004, 11:19 AM
OverBoardProject OverBoardProject is offline
Banned
you need more than a propane torch, try using an oxy-acetalen torch... and on the metal right around the sensor.
when the metal just turns red hot turn the torch off, and let it cool for a few minuits. it should come out then.
Old 12-05-2004, 07:40 PM
mike1224's Avatar
Re: Re: Stubborn O2 sensor (front)
we tried heating the exhaust by runnning the engine. we're using an o2 remover.
2002 Chevy S-10 ZR2
Old 12-05-2004, 09:53 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
be careful if you use oxy-acetalen or you will put a hole in the manifold. try propane first if you haven't yet.
if you again are careful try a breaker bar.
Old 12-05-2004, 10:14 PM
Banned
a propane torch probably won't get it any hotter that driving for 10 min, which isn't any where hot enough.
the manifold has basicly rust welded the oxy sensor in there, which will require a lot of heat to un-weld
this problem happens all the time with exhaust manifolds, although It doesn't seem to happen to headers
one of those hobby propane - oxygen torches that use camping style tanks might just get it hot enough, although you'll be out there for a while
