Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-05-2004, 08:11 AM
adeeos adeeos is offline
PLEASE HELP: 2001 Yucon HEAT will not turn off
Hi,
I have a 2001 Yucon XL and the heater will not turn off no matter where the settings are. You can place the heater setting in the blue (cool) and turn the A/C on (the light will light up) but still blow hot. As we drove home from Chicago yesterday with one rear window open, it started to blow cold by itself after two hours of blowing hot.
I have no clue what is going on and am certain that it would cost a fortune at a dealer. Does anyone have an idea? Thanks for any help/suggestons.
Old 12-08-2004, 10:41 PM
AtleyJackson AtleyJackson is offline
I can not take the heat.
I have the same problem. Works on in the morning. At night no control over the tem. Just hot. Let me know if you find a solution. I will post something when I tear in to the dash this weekend.
Old 12-29-2004, 09:40 PM
embinv embinv is offline
Heat won't turn off
Had a similar problem had blower but no heat and no control over which area i.e. vent,defrost, etc. Had to replace the AC control module. That is the complete control unit for heat, air etc. go to ebay and go to factoryautoparts. They have the switch for $96. Great price also.
Old 12-31-2004, 09:55 PM
Trip6614 Trip6614 is offline
Re: PLEASE HELP: 2001 Yucon HEAT will not turn off
Hey guys, I just tore into a A/C control modual on my 95 that has the same issues you are describing. I found a burnt resistor on the board and replaced it. Problem solved for under a buck!
