95 air question i havent seen yet
i have a 95 lincoln and the air ride has presented me with a problem i havent seen in this group. my left front dropped all the way down while the right rear has gone all the way up. it seems as if the air in the rear is fully extended, not just dropped in the front and is a reaction to it being lower. well the compressor is working but it isnt even trying to lift the left front and there isnt a air leak there. when it did drop my wife was driving and not sure what actually happend.
Re: 95 air question i havent seen yet
Sounds to me like you have a problem with the control module. Send me a PM and I will do my best to help you out.
air ride
I had the same problem with a 90 conty. the problem was the controll mod. i got one from ford $600 but later found that big a auto parts can get them cheeper.
Hello!
How can I check if my "control module" is working? I'm having problem with front suspensions: when I start the car (cold) they pumping up, but after about 10 min driving they go down and sometimes if I just shut off the car and start it again they start pumping again, but usualy I have to wait for about 30 minutes after stop the engine. Also, I've noticed that if I drive very carefuly (dont brake hard) or if I drive on smooth highway, they could stay pumped up for hours. Another thing I noticed is that the pump itself (that located inder the hood) is not active during the driving (well, sometimes I could hear it pumping, when I stop on traphic light). I kinda hope its the control module and not the struts... If its the module, where can I find it in the car? Thank you! P.S. I just remmembered, in the trunk there is a switch to shut off the suspension system, when I switch it to off and then to on, I can hear a relay click inside the trunk...I asume its for the rear suspensions? is it normal? |
Was a simple fix for me
I had the same prob with my rear end leveler system. I took it to a independent ex Ford garage mechanic - He researced it on the web and he found it was a bare wire to the system shorting out - He siad it was the blue wire - says it can happen and has many times. Take it to your garage and have them check the blue wire to the leveling system - Only costed me $75.00 - Quick fix!
