Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 12-05-2004, 07:27 AM
shaun1982 shaun1982 is offline
air filter question
hey guys, i just bought a 92 prelude si (H23 engine) and like my vtec civic, it had a k & n short ram filter on it when i bought it. and sound was sick ass. the hissing sound.
now. i always see the cars from spoon using the stock filters. what do thgey just replace the thing inside the stock filter. so am i able to do the same. so i can have the stock look filter but with a better filtration system in side it from brands such as k &N and is it easy as taking off the cover and replacing it. and cause the short ram filter sucks in hot air. what about when i use the stock filter box. and will i get the hissing sound if i just replace the filter inside the stock box
thanks
Old 12-05-2004, 10:37 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
K&N makes drop-in type filters, so you can keep your stock airbox. You'll lose the hissing sound though.
Old 12-06-2004, 10:16 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: air filter question
The air filter is right behind the battery anyways.. there is no hot air over there.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 12-09-2004, 05:39 PM
Interlude Interlude is offline
Put in a drop in filter... Spoon makes one for the 5th gen, I don't know about a Spoon filter for the 4th gen tho.
Old 12-09-2004, 05:53 PM
SiGNAL748's Avatar
Re: Re: air filter question
afaik, 4th gen and 5th gen airboxes are the same.
Old 12-09-2004, 07:17 PM
Re: Re: Re: air filter question
You learn something new everyday...
Old 12-13-2004, 11:27 PM
unknownluder69 unknownluder69 is offline
y dont u just get a cold air intake. if im not mistaken they actually add horsepower but dont have the hissing sound. besides cold air is better than hot air for performance so y would u want to suk in hot air?
Old 12-19-2004, 07:09 AM
JaCkNesS JaCkNesS is offline
only problem with cold air intake is during Winter... or when it's raining. You dont want water getting near it.
Driving you car is like making love to a beautiful woman... except its in the front seat.
Old 12-19-2004, 11:01 AM
jwd3jdm jwd3jdm is offline
Rain isn't a problem with cold air intakes unless you plan on swimming with your car. The filter has to be completely submerged to water log your motor. Why would they make a product if you couldnt use if in every day driving conditions? Winter is never bad for a cold air intake, that is where its power shows the most, because of all the cold air it has access to. Anyway, if you want to use the stock box, I recommend taking out the lower part of the air box, the part that goes down under your fender and into gay airboxes that rob hp. There is a butterfly valve down here that you really dont want if you're lookin for power. Cut the top of this second piece off so that it will still clip on to your top box, so the new filter wont fall out, buy a drop in air filter, put it in, clip the two together and lay it right on top of the now open hole that you have in your engine bay by the front right fender. Make sure you get all the crap out of the bottom part of the fender first so that you can see straight down to the ground. This will be like a cold air/ short ram intake hybrid, and it will look stock. Good luck!!
Old 12-19-2004, 11:04 AM
If you really want something awesome and JDM, buy a universal ARC brand filter, it has plexiglass on top of an orange filter that will just slide right in to the intake tube, so now you've taken out the entire airbox system and you can see that phat square, box style intake, and still retain the factory intake tube for that clean look.
