Old 12-05-2004, 07:14 AM
ARK51294 ARK51294 is offline
Shaking
2000 Cherokee Freshly balanced and new tires and rims. When I hit 70 - 80ish Theres a noise from the front and slight vibration on the passenger side. Any clues? Thanks
Old 12-05-2004, 10:18 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Shaking
If this problem was NOT there before the tire swap, take it back and have the tire shop check the tires for balance, out of round and also for wheel trueness. You might have received some defective parts.
If the tires are larger, or the rims have a different size or offset, they might be placing a greater strain on the front end, allowing an existing worn steering or suspension problem to make itself known. In this case, check ball joints, wheel bearings, tie rod ends, shocks etc.
Old 12-05-2004, 11:14 AM
Re: Shaking
It had some shaking at lower speeds before the new tires and rims now it is just when it gets up there.
Old 12-05-2004, 01:03 PM
MagicRat's Avatar
Re: Re: Shaking
Try changing the front tires to the rear and vice versa.
If the condition persists, check the front suspension/steering for worn or damaged components.
Old 12-05-2004, 02:40 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
My first move would be to go back to dealer and have them spin them again, than try the front to rear swap, or better yet have them swap them while you are there.
