Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-05-2004, 04:18 AM
GT500916's Avatar
GT500916 GT500916 is offline
Banned
Send a message via AIM to GT500916
Im thinking about getting these wheels...
what you guys think?
These are JDM 5-ZIGEN TYPHOON
17x8 +27 front
17x9 +35 rear
the tires i want to put are 255/ 35 or 40? rear and 235/ 40 or 45 on the front..
would i have any fitting problems with those offsets? and what about the tire sizes should i go different ?
Old 12-05-2004, 05:22 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
i would put the 45s on the rear and 40s on the front...or leave them the same. it doesnt matter. just figure out which height on the 17" wheels will keep your speedometer the most accurate and go from there.
nice wheels...what do they weigh in at???
ZedEx Crew Member #4
Old 12-05-2004, 11:17 AM
TatII TatII is offline
the rear offset is perfect. you can fit either 255 on those or 265's.
my friend has a set with 245's on them and they're too skinny for that wheel. it looks stretched. so atleast a 255 on those. the front ones will fit 235's perfectly. and i think 27 offset is perfect too.
i regret gettin my 5 zigen typhoons because i got them in such a bad offset. i had them at 40 all around at 7.5 inches wide
but i got them for 800 bucks new shipped with tires. thats why i got them.
but nice deal. they look really nice on S14's. how much are you getting those for?
if you want to keep the speedo accurate. the stock wheel height is
205/55r16 i believe. so thats 205x.55=112mm
112mm/25.4= 4.409 inches for the side wall. so that x 2 = 8.818 inche
rim heigth is 16+ 2 side wall height so thats 16 + 8.818= 24.82 inches diameter
if you want to mount 255 wide wheels in the rear on 17's. the size needs to be
you will need 255/40R17. according that that same calculations the height will be 25.0 inches flat.
if your running 255/35R17. then it will be too short at 24. inches flat. i'd rather run a slightly taller taller tire becasu when the tire wears out by only 2 tenths of an inch your speedo would be perfect. while the other will be underdriven too much.
if you want to run 265's in the rear. you will need
235/45R17. this will give you the total height off 24.4 inches almost a perfect match for the stock tires.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 12-05-2004, 12:15 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Is there some way of adjusting the speedo?
Old 12-05-2004, 01:31 PM
Chuki_breath Chuki_breath is offline
Re: Im thinking about getting these wheels...
nice man those should look damn good. Typhoon are nice wheels. I'd cop those.
Old 12-05-2004, 07:52 PM
GT500916's Avatar
Banned
i think those are like 20lbs each or something... here i have a good link for checking on wheel weights keep it, it comes in handy
http://www.superhonda.com/tech/wheel_weights.html
and isnt it the wider you go the less you should go ni the sidewall because its like the % of the width or something, i dont remember, thats why some people have 35 rear and 40 front but yet the rear look same as front sometimes taller because its actually wider...
Old 12-05-2004, 07:53 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
sweet
yea im pretty sure you can reconfig the Speedometer, and those Typhoons will be pretty awesome on your black S14... good selection
Old 12-05-2004, 07:54 PM
GT500916's Avatar
Banned
no i dont think there is a way to adjust the speedo, because its electronical , but then again im not sure... but its pointless to adjust it when you can just same height wheel and tire set up..
Old 12-05-2004, 10:09 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Bleh
any offset above 30 on an S14 is weaksauce.
Good Cheap/Light Wheels
5Zigen FN01R-C
17x9 +15 F 235/45
17x10 +12 R 255/40
800 bucks without tires.
Old 12-06-2004, 01:38 PM
S13wanabe's Avatar
S13wanabe S13wanabe is offline
Get the Advan three spoke wheels. Expensive, but woth it. Those are the most kick ass wheels on the s14's and s15's.
Old 12-06-2004, 04:14 PM
GT500916's Avatar
Banned
NEVER!!
5 or 6 or maybe even 8 but not 3 ...
Old 12-06-2004, 04:21 PM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
those advan are lovely on s13's. its teh hotsauce, lol (R.W.240)
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
