Replacing and oxygen (0 2) sensor
If you're having a problem with your 'oxygen sensor' it shouldn't be too hard to replace. I did mine on my 91 explorer with a 93 engine.
the sensor should be under the passenger side, and under the engine. It will be just below where the exhaust pipe hooks up with the 'catalytic converter' . You'll need I belive a 3/4 inch wrench to take it out. It shouldn't be there to tight but be careful because there might be some rust on it because it goes into the exhaust system.
Once you have undone, find a long stick, and stick up through an engine hole to see where the plug is. The plug in should be at the back of the engine. That is why you use the stick to get and idea of where to reach. Find the wiring, and disconnect it and replace it with the new one.
Best to use car ramps to get underneath. Don't use jacks as a support system not unless you have some good blocks to support the explorer.
The 'oxygen sensor' doesn't have to really tight when you put it back in. Read the instructions if you do it yourself.
