Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-05-2004, 02:30 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Car's broke
I've got a nasty clicking/knocking sound coming from the driver's side front wheel, and it gets a lot louder when I'm just cruising or let off the gas. At full throttle it hardly does it at all though. Also, after giving it some gas and trying to brake, I have to hit the brake pedal a few times to go from total mush to stopping power. I just got new axels, think they're junk? The boot is in fine shape.. Maybe it's a rotor warped to hell? Maybe my caliper crapped out? I haven't taken the wheel off to check yet, just thought I'd ask here first.
Old 12-05-2004, 03:36 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
Re: Car's broke
if you have to pump your brake pedal to build pressure i would be concerned. check over your caliper and rotor. look for a fluid leak around the caliper or cracks in the rotor, etc.
LS1 RX-7 Zoom Zoom
Old 12-06-2004, 08:56 AM
BennyBakwood007 BennyBakwood007 is offline
Re: Car's broke
This might sound basic, but check to see if your wheel bolts are tight enough...i had a similar prob a few weeks ago with the knockin and pinging sound from my tire...turns out my wheel was about to fall off...not sure about the braking situation though
97 EX
What do i say to a Dead Cops wife??
Cops kill my People Everyday...thats LIFE!!!
Old 12-06-2004, 01:20 PM
Ricochet's Avatar
Banned
Re: Re: Car's broke
I checked last night and that's what was wrong. I'm pissed because I can't find out why they keep loosening though.
Old 12-06-2004, 01:22 PM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
Re: Car's broke
So its all good now ? That was an easy fix. I cant figure out why they would loosen on there own tho mmmmm.
Old 12-06-2004, 01:42 PM
ridestreet84's Avatar
ridestreet84 ridestreet84 is offline
Send a message via MSN to ridestreet84
this may be dumb of me to ask but do you tighten them by feel or do you torque them to the right rate they just may not be torqued down enough
Goodbye civic Hello turbo outback goodbye outback Hello WRX
Old 12-06-2004, 01:53 PM
Ricochet's Avatar
Banned
Re: Car's broke
I have a torque wrench.
Old 12-06-2004, 02:19 PM
Re: Car's broke
I step on the on the wrench until it doenst move anymore
97 EX
Old 12-06-2004, 02:37 PM
Ricochet's Avatar
Banned
Re: Re: Car's broke
Congratulations, hope you enjoy changing out stripped lug bolts.
Old 12-06-2004, 03:54 PM
Re: Car's broke
10 years, 4 cars, and not 1 stripped bolt...must be doing something right....
97 EX
Old 12-06-2004, 06:31 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Car's broke
Id check both the threads on the stud and bolt, one of them may be stripped
Old 12-06-2004, 09:36 PM
Ricochet's Avatar
Banned
Re: Car's broke
None were stripped. I tightened them all down to 80 ft/lbs, took a 20 minute trip to school, and by then they were all hand-loose. I took out my lugwrench and tightened them all down as hard as I freaking could, drove home and had no problems. When I got home I took my wheels off to change the pads/rotors and I didn't just strip a stud, but the fucking thing broke off with the lug nut!
I tapped out the stud and put a new one in with all new lug nuts on that wheel, so hopefully this along with new pads/rotors will remedy my problem.
Old 12-07-2004, 12:38 PM
Kind of a Big Deal
Re: Car's broke
well, good luck with it.
Old 12-07-2004, 06:21 PM
exman98 exman98 is offline
Re: Car's broke
would the "lock tight" fluid be a bad idea.
Old 12-07-2004, 06:37 PM
Kind of a Big Deal
Re: Car's broke
it shouldnt be needed, there is something else causing the problem and using loc-tite would only be a temp fix, i think he should investigate and try and fix the problem instead of covering it up.
Closed Thread
