Go Back   Automotive Forums Car Chat > Ferrari > 348 | 355
Old 12-05-2004, 12:07 AM
johnnyBgood johnnyBgood is offline
Send a message via AIM to johnnyBgood
Ferrari F355 Twin Turbo
The Nizpro F355TT kit is available in two stages, a 6psi/575hp Stage 1 and 13psi/750hp Stage 2. This twin turbo kit provides the power and response that your Ferrari craves. More pictures and a video are coming soon. PM for more details. This has just been released to the public.
Performance (13psi level, 6psi coming soon)
0-62mph: 3.2 seconds
0-100: 7.9 seconds
Standing 1/4 mi: 10.5 seconds at 140mph
Top Speed: 220mph
Stage 1 creates 575hp at 6psi and contains the following:
-Preprogrammed MoTec ECU M800 with plug in loom adaptors (can be upgraded to include traction control, Lambda, logging, and so forth)
-MoTec loom and associated fuses
-High flow 4-spray fuel injectors
-Twin high-flow Garrett GT ball bearing turbochargers
-45mm Turbosmart Pro-Gate wastegate
-Twin custom high volume tube and fin intercoolers with cast tanks
-Thermatic fans on each intercooler with On temp of 28C(83F) and 22C(72F) Off via MoTec switching
-Custom large volume Air Cleaner box with low restriction K&N filter element mounted under the hood and associated tubing, cast in aluminum in either polished or powdercoated finish, depending on customer requirements
-Turbocharger exhaust manifolds made from 3mm stainless steel or cast depending on application (with catalytic converter or without)
-Cast stainless steel wastegate plumbing
-Twin cast aluminum pipe from inlet manifold to intercooler pipes
-4x76mm rubber "hump" hoses (intercooler/inlet)
-6x76mm silicon rubber hoses (turbocharger to intercooler and turbo to air cleaner plumbing)
-20 stainless steel hose clamps
-2 aluminum weld on -10 sump fittings for turbo drain back hoses (depending on quantity, we will cast a higher volume CNC machined sump with integral drain back holes)
-2 braided stainless steel turbo drain back hoses
-2 braided stainless steel turbo feed hoses
-4 braided stainless steel water feed and return hoses
-All copper wahsers, banjo bolts, T-pieces, gaskets and hose clamps to suit above
-High-Flow dual inlet and twin outlet 3-inch in and out stainless steel muffler
-CNC laser cut turbo mounting bracket
Stage 2 creates 750hp at 13psi and contains the following:
-High Volume package
-Modified programming of MoTec
-Modified wastegate
-High volume fuel pump
Old 03-01-2005, 10:18 AM
Re: Ferrari F355 Twin Turbo
This is for sale in the US now. Installation time is 2 days and does not require an engine out, just a lift.
The car is/has been running stock internals on 13psi of boost for the past 2-3 months. The car has been driven over 8000 miles with no detonation or clutch slip (on the stock clutch).
Dyno wise, the car is laying down 603whp at 13psi. At 6psi, the car made 475whp. The 0-60 times for the 6psi and 13psi are even (due to tire slip at 13psi) at 3.2-3.5 seconds.
See it in next months Modified L&E in the US and Motor Magazine in AU.
Here is a video: http://fiautosports.com/Ferrari/images/F355TT_drag.avi
Old 09-05-2005, 11:47 AM
stav1369 stav1369 is offline
http://stav.webspot.com.au/355%20turbo%20drag.avi
THIS is a video of a Nispro 355 trubo in Aust at calder park (melbounre drag strip)
I also have a stock F355 GTS and ran 13.447 @ 105.27
http://stav.webspot.com.au/calder%20ferrari.jpg
Old 09-29-2007, 05:55 AM
peterpaul peterpaul is offline
Hi,
Ferrari F355 is a great car with great color range and speed pick up.The performance is really off beaten.It has
Nail care products | Compact Mirrors
