Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 03-01-2002, 08:28 AM
ImportFanatics.com's Avatar
ImportFanatics.com ImportFanatics.com is offline
Banned
Send a message via AIM to ImportFanatics.com
3000GT vs Camaro SS
Who would win in a race?
Stock 3000GT vs Camaro SS...any years.. This question came up in a chat and caused everyone to go crazy. Just wanted to know what you guys think.
If the Camaro is faster..What about the 3000 GT VR-4 vs Camaro SS?
Thanx!
Old 03-01-2002, 02:18 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
There are just to many year to year combinations to go through as well as wether its from a stop, from a roll and all the rest of it. If you want pure power - go with a SS. If you want refined power - go with a VR4. If you want to know who wins the race. Draw up some parameters and we'll be glad to give our opinions.
Resistance Is Futile (If < 1ohm)
Old 05-30-2002, 12:53 PM
benzvr4 benzvr4 is offline
Smile
I have a 95 vr4 and i have imbarrassed many camaros and transams i guess it all depends if you want an import or a domestic
Old 06-04-2002, 05:36 PM
VIN_DIESEL VIN_DIESEL is offline
Send a message via AIM to VIN_DIESEL
an NA has no chance against an LS1 camaro.
-K&N intake
-Underdrive pulley
-Jacob's Electronics Spark Plug Wires
-17" Niche Shocking Shock Rims
Wrapped in Yokohama AVS DB
-18" OZ Racing F1 cup rims wrapped in Potenza's
-Ultimate Performance Front strut brace
-Red Brake calipers
-Custom Exhaust with N1 Mufflers
-Hella H4 Conversion with true HID
-PIAA 912 Fog Lights
-Alpine CVA-1005 and CHA-S604
-MB Quart PKC 116 in the doors , Custom Box with MB Quart QM 200.03 KX
-Dual Fosgate 100.2's
-1 Farad Stinger Digital cap
Old 06-30-2002, 08:56 AM
Ando_Rules Ando_Rules is offline
id say the camaro would win it, but the 3000gt would definatly be close
Old 07-31-2002, 08:20 PM
CarFreakBenP CarFreakBenP is offline
Send a message via Yahoo to CarFreakBenP
In my opinion, the 3000GT SL would not have a chance against the SS, the SL with 270hp and weighing almost 4000pounds is no match. The 3000GT VR-4 on the other hand, with 320hp and 315lb torque would be a fair match.
Old 07-31-2002, 10:21 PM
your specs are wrong. The SL has 220 hp and weighs roughly 3200 lbs. It would beat an LT1 camaro in a long race but has no shot against an LS1.
-K&N intake
-Underdrive pulley
-Red Brake calipers
Old 08-02-2002, 04:43 PM
96 LT1-Z 96 LT1-Z is offline
An SL will NOT beat an LT1 Camaro in a long race. An SL won't beat my Accord in a long race without a power adder.
96 Z-28 M6
13.92 @ 101.7 before bolt on's
91 Ex Accord Coupe
h22a swap
bolt on's
00 SE Maxima 5M
Greddy Evo
Frankencar intake
Old 08-02-2002, 10:15 PM
what does your LT1 top out at? 120mph? SL tops out at over 140mph. LT1's run out of steam fast when they get reach higher rpm ranges. Also, an SL would make short work out of any Normally aspirated accord.
-K&N intake
-Underdrive pulley
-Red Brake calipers
Old 08-03-2002, 05:04 PM
Lt1's top out at over 150mph. You must be confusing an LT1 camaro with a v-6 Camaro. I have personally buried the speedo and going by rpm, have topped 160. An LT1 with the stock tire size and 3.42 rear will hit the 6200 rpm fuel cutoff in 5th at 166 mph. THe only LT1's that top out around 120 are the ones that were purchased without Z- rated tires. They came with a governor and are easily identified by the 115 mph speedo as oppossed to a 155 mph speedo. The dealer would remove the limiter if you came back with z rated tires, or you could have it done with a simple aftermarket programmer. As for my Accord, if you check my sig it has an h22 with bolt -ons and trust me, has more than enough to handle a similarly modded SL, topping out at 140+.
96 Z-28 M6
91 Ex Accord Coupe
h22a swap
bolt on's
00 SE Maxima 5M
Greddy Evo
Frankencar intake
Old 08-05-2002, 10:50 AM
NSX-R-SSJ20K's Avatar
NSX-R-SSJ20K NSX-R-SSJ20K is offline
Send a message via AIM to NSX-R-SSJ20K
thats obvious
tho a VR4 would whoop the Camaro V8's i already know cuz i know dis and witnessed it
its not proven till you tried it
Qualified Automotive Engineer
Old 08-05-2002, 10:30 PM
blackbob's Avatar
blackbob blackbob is offline
Send a message via ICQ to blackbob Send a message via AIM to blackbob Send a message via MSN to blackbob Send a message via Yahoo to blackbob
Exclamation Ok
i wonder what would happen if you got a camaro with all japanese parts ? Would it be better or worse ?
RogueRacing
"Dare to be different"
SHIFT_imagination
Old 08-06-2002, 07:53 AM
Stock vs Stock, a VR4 and an LS1 Camaro would be a driver's race in most cases. The VR4's ran mid 13's stock, where as the average LS1 run's mid to low 13's stock. An LS1 with an excellent driver is however capable of a high 12 sock.THe VR4 is rated at 320 hp and weighs about 3800 lbs. An LS1 F-body is rated at between 305-335 depending on year and model(though it is widely knowncthat theyreally have between 340-350 hp stock) and weighs about 3300lbs. THe VR4's advantage will be on the launch. Aftetr that I believe the LS1 car will run it down.
96 Z-28 M6
91 Ex Accord Coupe
h22a swap
bolt on's
00 SE Maxima 5M
Greddy Evo
Frankencar intake
Old 08-06-2002, 11:59 AM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
The SS and Z28 would beat any trim 3000gt in a short or long race.
Only the VR4 would win off the line due to its AWD.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 08-10-2002, 10:12 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
I agree with LT1-Z, the VR4 would have a large advantage at the start but i think the muscle of the camaro would eventually take the race.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
Any1 Trading 3000GT? Auto Or Stick please look WANTED3k 3000GT/Stealth 0 07-30-2009 11:46 PM
Check out my new 3000gt/Stealth Site! inflam52 3000GT/Stealth 7 07-15-2009 03:41 PM
For Sale 1999 3000gt $6,800 Jawz_3kgt Cars/Parts for Sale/Exchange 1 06-30-2009 07:43 AM
For Sale 1999 3000gt $6,800 Jawz_3kgt Cars/Parts for Sale/Exchange 0 06-29-2009 10:25 PM
