Old 12-04-2004, 10:47 PM
DisturbedX DisturbedX is offline
Looking to buy...
I am looking to buy a 3000gt from the price range of about 1500-3000$ please email me at [email protected]
Old 12-04-2004, 11:21 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Looking to buy...
Check out autotrader, no one on here has one for that price and you will be hard pressed to find one for that price thats not a first generation with over 120k miles.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-05-2004, 01:11 AM
Im looking for something thats moving but could use some work because I plan on pulling it apart anyways.
Old 12-05-2004, 01:23 AM
Thourun's Avatar
What are your full plans for the car?
1995 3000GT VR-4
Old 12-05-2004, 02:53 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
1500-3000 will get you a P.O.S. or you would have to find a GREAT deal on a car with pretty high mileage. and definitely it would be 1st gen as Thourun suggested. But beware, cars with very high mileage, however well they were taken care of/maintained, most likely there will be other problems that are about to happen.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-05-2004, 04:03 PM
Well actually Ihave a 1st gen VR4 thats wrecked that im gonna part out everything under the hood is intact but the b0dy is totally fucked I got it for 1800$
Old 12-05-2004, 05:30 PM
Igovert500's Avatar
blue + red light magnet
Rather than parting it out...why not save it, so when you buy whatever new vr4, you have donor parts...perhaps between the 2, you could put together one decently running vr4.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-05-2004, 06:00 PM
Ya I have it pulled apart in my garage so i am just looking for a shell to put it in and I plan on selling whatever i pull out of the non-vr4
