Old 12-04-2004, 08:29 PM
ciaramita ciaramita is offline
Problems with my 1998 GTP. Please help.
Ok I am having some problems with my GTP.
1. The belt is making some funny noise and its getting worse each day. A buddy told me I need a new belt so Im getting one tomorrow. However when I turn the heat on it goes away and when I turn it off it comes back on.
2. Just today I turned the car on and it hesitated for about 5 seconds. I kept the key turned foward and it kept turning over but not starting. It finally did start. I tried it again and had the same problem. I drove straight home and turned the car off and then turned it back on with no problems.
3. The heater has no heat and hardly pushes anything out. I turned it on level 5 and felt just a little bit of cold air coming out.
Thanks for the help
Old 12-04-2004, 10:41 PM
bcreverend's Avatar
bcreverend bcreverend is offline
motor blower
bad motor blower?
silver 99 grand prix gtp with Intense standard pcm, 3.4 intense modular pulley, oversized supercharger idler pulley, zzp underdrive water pulley, zzp overdrive alternator pulley, tps enhancer, open cone filter, thrasher shift kit, strut tower bar, eibach springs, autolite spark plugs, 180 degree t-stat, throttle body spacer, flowmaster catback w/U-bend delete, Rear O2 simulator, silvania headlights, xenon foglights, 40 cp reverse lights, and a custom 600 watt audio with cd changer.
Old 12-05-2004, 12:58 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Sounds like you are having a problem with the Blower motor resistor
Check out this thread Click Here
ClubGP Member 6530
Since 2001
