Old 12-04-2004, 06:23 PM
DJ RaYgU's Avatar
DJ RaYgU DJ RaYgU is offline
Wetsanding???
How do u actually "wetsand"??? I cant seem to find this in the faq. and when u "wetsand", do u use a circular sanding motion?? thanks everyone.
Current Project:
Fujimi Veilside Combat Silvia S14...almost finished
Old 12-04-2004, 07:12 PM
cooltc2004's Avatar
cooltc2004 cooltc2004 is offline
Send a message via AIM to cooltc2004
Re: Wetsanding???
Wetsanding involves water and sanding, as the name suggests. Either you can dip the sand paper in the water, or you can run water over the entire vehicle and sand. You do not have to sand in circles.
Old 12-04-2004, 07:13 PM
DukeMan's Avatar
DukeMan DukeMan is offline
I hold the object I´m sanding over a water-bowl and sand it by making circular motion and dipping the abrasive in the water frequently.
Regards, Fredrik
/Fredrik
Current Projects:
-´70 Camaro Z28 (Baldwin Motion hood wanted!!!)
-´32 Ford Roadster (on hold)
´69 Camaro thread
Old 12-04-2004, 07:30 PM
minniebanister minniebanister is offline
Re: Wetsanding???
I'd always thought that wetsanding was something to do with wetdreaming. Maybe I'm wrong.
Old 12-04-2004, 07:58 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Wetsanding???
I use a spray bottle and some sandpaper spraying the surface constantly.
-Mike
Old 12-04-2004, 08:42 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Re: Re: Wetsanding???
I place the model under running water while sanding it first with P800 Grit then 2000 Grit.
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 12-05-2004, 12:06 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
Re: Wetsanding???
Damn....that's some rough-ass grit.
nightmaR3Z
Old 12-05-2004, 12:29 AM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
Re: Wetsanding???
I do running water and 1200 grit.
Project Lexus Revive
Old 12-05-2004, 08:39 AM
mike@af's Avatar
When working on 1:1 I've wet color sanded using 600grit, then moving up to 1500 from there, with excellent results.
-Mike
Old 12-05-2004, 09:47 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Add a little dishwashing detergent, 5 drops per quart/litre. This will help keep the sandpaper clean and lessen the chance of the debris you are removing from causing other scratches. - Mark
Old 12-05-2004, 10:30 AM
nis.k.a.'s Avatar
Re: Re: Re: Wetsanding???
Apples and oranges.
In most cases wetsanding with 3200 can be too rough on my model finish.
nightmaR3Z
Old 12-05-2004, 10:40 AM
ImolaEK's Avatar
Re: Re: Re: Re: Wetsanding???
Apples and oranges.
I usually used 1000 grit first to remove all the mold lines etc. But now with P800 its easier to remove all the mold lines and then move on to 2000 grit. I haven't found any higher grits around here yet. Ive been dying to find 4000 grits, etc.
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
Old 12-05-2004, 11:31 PM
bvia's Avatar
bvia bvia is offline
Re: Wetsanding???
BINGO! as that is exactly how I do it. I also have an old tupperware rectangluar "bowl" for this and only this.
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
Old 12-06-2004, 06:36 AM
mike@af's Avatar
Re: Re: Re: Re: Re: Wetsanding???
Go to your LHS. Detail Master has 12000.
-Mike
Old 12-08-2004, 10:20 PM
bvia's Avatar
Re: Re: Re: Re: Re: Re: Wetsanding???
They carry a polishing cloth that is labelled "12,000", but that number does NOT correlate to the numbers you find on 3M or suitable wet-n-dry sand paper...which is confusing and strange.
Bill
