Old 12-04-2004, 06:02 PM
darrbonn darrbonn is offline
sliding door panel removal
What would be the easiest way to remove the inside panel off the power sliding door. The door wont open its stuck in the lock position. Thats why I need it off to repair it.
Old 12-18-2004, 09:13 PM
CTCarpenter CTCarpenter is offline
Re: sliding door panel removal
I have the same problem. The only way the door will open is from the exterior (kid lockout is off). Hopefully there will be an answer soon.
Old 12-20-2004, 12:20 PM
Dngrsone's Avatar
Dngrsone Dngrsone is offline
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
The hardest part is getting the handle off--
Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
You should be able to remove the panel from the inside.
2003 Ford Expedition 4.6L (Dngrswife's)
2006 Kia Sedona
2008 Toyota Prius (totaled)
1997 Windstar 3.8 liter (retired)
Replaced Head Gaskets
1988 S-10 2.8 liter (retired)
Full Rebuild
