Old 12-04-2004, 05:48 PM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
d16a1 and zc
I have a d16a1 and I am going to buy a zc from 4g4dstore in a week or so. I have heard that the only difference between the zc and the d16a1 is the cams. Correct me if im wrong and add anything else that is differnet thanks.
a d16a1 is the motor out of an 89 integra USDM version
Old 12-04-2004, 06:01 PM
POSRacing POSRacing is offline
Send a message via AIM to POSRacing Send a message via Yahoo to POSRacing
Re: d16a1 and zc
Well i assume youre buying the sohc zc and not the dohc zc and yes as far as i know the only difference is the more aggresive cam in the zc
Old 12-04-2004, 06:11 PM
travagliante's Avatar
travagliante travagliante is offline
Re: d16a1 and zc
The main difference is that it WILL NOT work in a 4th gen.
Andrew
Old 12-04-2004, 06:21 PM
Beater88 Beater88 is offline
Re: d16a1 and zc
The d16a1 is a USDM DOHC 87-89 integra.
It will work but the hassle is not worth the work. But it will fit a gen1 CRX or gen3 civic, dropin. I did it once, not much room for anything else.
As for you assumtion the DOHC ZC and DOHC d16a1 are the same except for the block mounts for the ZC will work easy for 4gen but the d16a1 are total wrong and will have to be custom made to work and there are some body mods too, like I said not worth the effort.
Old 12-04-2004, 06:36 PM
Re: d16a1 and zc
the rex allready has a d16a1 in it but the block is cracked that is why i am buying that zc dohc block. i was currious if i could put the rods and pistons in untill i get new ones and also but the head on the block
Old 12-04-2004, 06:53 PM
Re: d16a1 and zc
duhh im a moron i was thinking of the d16a6, the zc dohc goes right into a 4th gen i know because i put one in my 91 crux, i had a little trouble with the back mount, but thats all as far as putting it in
Old 12-04-2004, 07:23 PM
Re: Re: d16a1 and zc
Are you sure its a d16a1, because it would require more work than its worth for a power gain of 9hp over stock (si, ex models) or 22hp over stock (for dx models) Id double check! But the rods and pistons are interchangable b/w zc and d16a1.
And the d16a1 came in USDM 86-89 Integras!
Old 12-24-2004, 05:54 AM
Re: d16a1 and zc
does the d16a1 head bolt up to the zc block fine
