Go Back   Automotive Forums Car Chat > Ford > Probe
Old 12-04-2004, 04:44 PM
Rhi_bruette Rhi_bruette is offline
Question my 89 probe is having battery probs, help?!
My car is dead. I thaught maybe it was a bad battery so i had it jumped and got it looked at, they told me my battery was good. I went and had my alternator looked at right after and i was told it was good. When i get my car jumped it works all day but by the time i get up in the morning it is dead again. i have cleaned off the clamps and tightend them, what else could it be?
Old 12-04-2004, 05:10 PM
Kanibal's Avatar
Kanibal Kanibal is offline
Re: my 89 probe is having battery probs, help?!
I had the same problem with my first gen but it was my alternator.
have you made sure no lights are being left on like in the trunk?
Old 12-04-2004, 05:16 PM
I havent checked the trunk but wouldnt my lights go out if my trunk is shut?
Old 12-05-2004, 01:47 AM
Kanibal's Avatar
the switch in mine broke off and the light stayed on. I was scratching my head for a few days. do you have a power antenna and does it still work?
somtimes the power antenna malfunctions and will run when the car is off, draining your battery.
Old 12-23-2004, 04:27 PM
Talking
I finally figured out what went wrong. apparently my radio memory was draining up to nine volts of my battery as soon as i turned off my car. how weird was that?! i just took my radio fuse out and the problem is solved. All i have to do now is replace the radio with a new one and it will be fine. I would have never guessed that was the problem. I went out and baught a new batt, fuses, and clamps before i took it and got it looked at by a pro. I am glad it finally works.
Old 12-27-2004, 09:30 AM
marineman12 marineman12 is offline
Send a message via AIM to marineman12 Send a message via MSN to marineman12 Send a message via Yahoo to marineman12
mine is having the same problem, but it all started when i removed the front bumper to get it replaced, could there be a sensor or wire that i damaged and is it draining the battery?
Joshua
Old 12-27-2004, 12:20 PM
i dont know... your bumper shouldnt have anything to do with the connection...I really know very little about cars, i had to go through and replace my battery connections, and replace fuses-that still didnt work. i took it somewhere and had someone trace the electrical problem.
Old 12-30-2004, 08:30 PM
jtecj jtecj is offline
Send a message via AIM to jtecj
you may have a bad ground somewhere from your battery have your lights been dim or anything has your car had any type of symptems when it was on? Cause what would happen is why its on the altenator is obviously recharging the battery so it will probably work fine but when you turn the car off the altenator stops working so a bad ground would cause it to lose power and lose it relatively fast.
