Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-04-2004, 02:41 PM
muskypro muskypro is offline
Angry Serpentine Replacement
I have a 1990 Jeep Cherokee 4.0 with air. How do I get this belt off??
Any advice appreciated!
Thanks
Stuck In The Garage!
Old 12-04-2004, 03:00 PM
gtmud gtmud is offline
Re: Serpentine Replacement
You will need I beleive a 15mm socket on a 1/2" breaker bar, or something long to move the tensioner pully away enough to remove the belt, becareful, thereis allot of tension on it,. I used a long 1/2" extension on mine. Just be aware of the routing, the key is to get the belt on all the pullys but the power steering.As you move the tensioner you'll be able to slide the beltinto place.
Old 12-04-2004, 04:02 PM
Dale Aeppli Dale Aeppli is offline
Thanks
the 4.0 doesn't have a tension adjuster i can send you a sheet for 4.0 can't send thru forum dale [email protected]
Old 12-05-2004, 10:59 AM
Saudade's Avatar
Saudade Saudade is offline
The adjusters are on the power steering pump. You need to loosen a few bolts that lock the pump in position, then you can back off the adjuster. Once you have enough slack, you can slip the belt off. PAY ATTENTION to the routing of the belt. Make sure the new one is seated properly.
Old 12-05-2004, 02:37 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
Just replaced mine, I also removed the air filter box for more room to get to adjuster bolt under p/s pump
Old 12-06-2004, 11:30 AM
Oops! Sorry there muskypro, I was thinking about my 91 chevy silver. In fact on my 00XJ there is a tensioner pulley adjustment bolt just in front of the PS pump, loosen it enough to remove the belt. As far a retightening the tensioner, Its more of a "feel", I adjusted it till my A/C stopped squealing, been fine eversince. Again, sorry for the miss info.
Old 01-12-2008, 03:21 PM
bew18 bew18 is offline
Which way does the adjustment bolt go to loosen and can i use a socket on a rachet?
Old 01-12-2008, 04:28 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Bew please do not revive threads that have been dead for 3 years start a new one as you did.
Old 01-13-2008, 10:46 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
This thread will be closed after this comment because it is quite old.
However, keep in mind that the early model used the PS pump to adjust the "S" belt and the late models have their own tension adjuster. No Cherokees used the automatic adjuster.
Closed Thread
