Go Back   Automotive Forums Car Chat > Buick > Century
Old 12-04-2004, 01:32 PM
trkd trkd is offline
cold weather starting
Our 1996 Buick Custom will not start below about 35 degrees after sittng out all night. When it warms up it starts and runs great. Holding the pedal down has no effect. It has a new max air flow sensor. No codes arfe being generated. Any ideas?
Old 12-04-2004, 01:38 PM
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
Re: cold weather starting
maybe i am missing something you say it runs great but then say when you push the pedal it does nothing for acceleration
i'd suggest check fuel pump seen alot of century problems like that
Nitrous= the car equivalent of a penis pump
Old 12-06-2004, 03:09 PM
johncv johncv is offline
Have your battery checked, when it is still cold. I had a car that when it was cold out would turn over forever but never start, when it warmed above 36 degrees, it would start fine. I swapped out the battery after trying many other parts and it worked fine. The problem is that older and / or lesser expensive batteries have a lower Cold Cranking Amp rating and there is not enough power to charge the ignition and fuel injectors. Hope this helps.
