Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-04-2004, 11:43 AM
tincan2 tincan2 is offline
1997 silverdo wont start
1997 silverado wont start, cranks. starts if started fluid sprayed into, then stalls instantly. replaced plugs, distributor cap, fuel filter and pump. any suggestions?
Old 12-04-2004, 02:20 PM
1977moneypit 1977moneypit is offline
Have you had the injectors cleaned/replaced? I would try an fuel injector additive that you just pour into your tank. Its a few bucks and is an easier route to start with then just going out and buying new injectors for about $70 a pop. Try that and I hope that works...if not, you know what happens next...
Old 12-25-2004, 02:07 PM
jmitschke jmitschke is offline
wont start
try pulling the fuel pump relay from the fuse block under the hood on the drivers side and bend the pins back about a 1/8th of a inch and reinstall it(making sure the pins still align with there respective holes) and push it down flat again. This makes the pins touch inside the fuse block and it sends 12 volts to the fuel pump and it runs until it builds 55 to 65 p.s.i.. You should hear the pump run when you turn the key to run. Good luck...john
Old 12-30-2004, 10:48 AM
emmitt69's Avatar
emmitt69 emmitt69 is offline
Re: 1997 silverdo wont start
I'm not sure exactly what it's called but it's a module that's on or near the distributer. Same thing happened to mine, costed 100$ parts and labor
