Old 12-04-2004, 10:13 AM
lambohawaii lambohawaii is offline
90 RS Wont Start
Someone please help Just purchased the car turn the ignition key nothing happens no dash lights no sounds nothing....Been reading all of the posts and have tried to trouble shoot I've checked the chip on the key and also checked the ignition switch all values are the same checked the fuses and yes i charged the battery still nothing the dome light and headlights do work I did purchase a a new switch and key the new key is not coded Switch is the same as the old has the 2 wires even has orange loom does anyone know if this will work or tried it its a 40.00 part at napa Did find or looks like the previous owner and taken the radio and amps out in a big hurry If the audio alarm assembly breaker is bad will this prevent a no start guess i'll keep looking and walking
Old 12-04-2004, 01:36 PM
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
Re: 90 RS Wont Start
did u by it not running?
Nitrous= the car equivalent of a penis pump
Old 12-04-2004, 02:20 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
ok, if you have already installed the new lock cylender with the two orange wires, and are using the copper blank key, it will not work. You have to go to the dealership and have them cut you a new ignition key, with a pellet resistor in it, the same value of your old ignition key for the system to operate.
However you mention that you have no interior lights. This sounds like a power supply problem. The power supply to whats under the hood, and to whats inside the car, are seperate systems. It sounds like you have a fault somewhere in your Interior power circuit. I do not have my shop manual with me, so i cant tell you exactly where to look.
You said you checked the fuses, did you only check the ones under the dash? or did you track down and check the underhood fuses?
Have you checked your battery positive battery cable? things to look for are corrotion, loose connections, rusted connections, insulation rub throughs. Also use a test light to check for power on both sides of your fuseable links. You may have had a power spike that fried your fuseable link to your interior power circuit.
Thats all i can think of off the top of my head, if youve already done those things, ill see if i can brainstorm a little more.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 12-04-2004, 02:41 PM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
I don't think riupping out the audio system would effect the starting of the car. When my stuff got jacked the hella ripped it out , open end wires arcing off crap and blew a crap load of fuses but I went out there and it started right up so I doubt it would be that unless it blew something somewhere else.
Might also want to test the battery. Just because it's charged doesn't mean it will work. It can hold 12 volts - 18 volts no problem but the first time you open up a channel of electric flow it will kill out. Just a thought.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 12-05-2004, 01:22 AM
Re: Re: 90 RS Wont Start
Thanks did find when amps were removed from trunk both hot and ground were left when i found these they were touching the hot goes to what looks like a distrubution block which is feed from battery and also supplies the alt and starter did replace starter today still nothing... do have power inside dome light and cig lighter do work....on a roll now
Old 12-05-2004, 09:29 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
You said you replaced the cylinder, how about the actual ignition switch?? I believe it's a 13 dollar part at autozone. I had a similier problem not to long ago. I would turn the key and nothing, starter was good, battery was good, vats was good, computer was good, lock cylinder and key where good. Traced it down to a faulty ignition switch. The only difference is my cluster lights where acting funny. If I had the headlights off when I turned the key the left side of the cluster would light up, if I had the lights on, the right side would light up. But check on that..good luck.
