Old 12-04-2004, 03:59 AM
NuBlackCavy NuBlackCavy is offline
Send a message via AIM to NuBlackCavy
Noisy AC compresser stories lets hear them!
I wonder if anyone has a cheap cure for running with a noisy ac compresser. While not engaged, it often "rings" like a bell that doesn't get hit. I just had my serpentine belt replaced about a month ago before taking a 1000 mile trip. Good thing! It was as thick as my thumb and was supposed to be about 2 inches wide! I thought that that would sovle the problem of the noise but the service tech told me that "worn compresser bearings are common with the Cavalier". Has anyone else had to deal with this issue? Did you have to dig into your pocket and replace the compresser in order to keep the engine quiet. Unfortunately, this DOESN'T sound like a job for a well placed can of WD40!
Old 12-04-2004, 07:34 AM
godenm's Avatar
godenm godenm is offline
Re: Noisy AC compresser stories lets hear them!
ive never had that problem with my cavalier,but i do in my 98 chevy 3500 diesel,the compressor will kick on for like a 1/2second every couple minutes,it drove me crazy so i unplugged it(which is bad for the seals)but it stopped the noise...
Old 12-04-2004, 09:39 AM
KJRich's Avatar
KJRich KJRich is offline
Send a message via AIM to KJRich Send a message via Yahoo to KJRich
I don't think there is a cheap way to fix this, you're looking at a rebuild or replacement.
1999 Chevy Venture LS Extended 3.4 V6 Intake Gaskets Replaced
2003 Cavalier LS Sport Coupe, 2.2 Eco, 5 speed Getrag, all black
Old 12-04-2004, 12:31 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
yep i just got a brand new one about 3 weeks ago .... no cash out of my pocket... my cost would have been 700 ... warrenty covered it.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 12-04-2004, 10:28 PM
pimpendacavi06 pimpendacavi06 is offline
ive never even ran my ac honestly forget that takes away to much power ill just put the window down and when its cold i just put a jacket on
Old 12-04-2004, 11:03 PM
Lifted GMT-360!
ok 1 question for you.... when its cold out, you don't run the A/C and by having the window down all your doing is promoting your self to catch a cold. Turning the heat on when its cold out actually takes the heat off your engine to heat the inside of your car helping the intake temps drop equaling a higher HP gain for yourself.... sorry but you left yourself open for that one.
Old 12-05-2004, 10:06 AM
KJRich's Avatar
Plus in the winter when you run the defroster the A/C compressor comes on automatically, anyway.
Old 12-05-2004, 05:48 PM
Re: Re: Noisy AC compresser stories lets hear them!
i wrote that in the winter i put the window up and put on a heavy quote i might have worded it wrong yea i prolly was open to that one i just dont usually run it no matter waht and as far as a defroster i just work it down in park then drive with it off
Old 12-05-2004, 05:58 PM
godenm's Avatar
damn,you must be after every h.p. you can get,haha... hell,what am i talkin about, i just got a belt to delete my a/c (took about 6 trips to part store to get right size) ,my a/c stopped working a while back due to not using it(the seals went bad).but the compressor was never noisy..
Old 10-24-2005, 11:13 AM
weaselsv weaselsv is offline
What size belt did you get to by pass the compressor? I am thinking about doing this to my girlfriends car to get through the winter and then replace the compressor in the spring.
Old 10-24-2005, 06:24 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
oh man, i thought i was the only one, a quick fix i have found is just turn your air conditioner on for a second or 2, then the noise will go away, then usually when i turn the air right back off, the noise is still gone
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-17-2010, 12:35 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Yes....I have a 96 2.2 with A/C that is bad...I want to get a short belt the bypasses the AC pump.... Doe anyone have the number Dayco, Drive, Goodyear..i really don't care what brand it is ... the AC unit noise is killing me !!!
Cheers mates...
Old 10-20-2010, 06:52 PM
Helmuth48's Avatar
Talking Re: Noisy AC compresser stories lets hear them!
I solved my problem. I bought a belt from Advance that does not use A/C. Belt fit right now with no problem. Noise gone...it was the clutch bearing... Now I realize I need to replace the whole unit...but I will not open it up until I have bought a new one.
Belt on Sale was $11.50...an A/C eliminator pulley with bracket is about $25...so I saved a few bucks.... This was 96 2.2 Cavalier, PS, AC with the belt tensioner just above the water pump ... 15mm socket. Belt is a Drive-Rite. 705K5...
Bottom line it worked for me... Cheers Mate...time a cold one !!!
The man from down under.....
